Idling problem
Old Aug 7, 2008 | 04:11 AM
kuks24's Avatar
Default Idling problem
OK. I had a check engine light on and it was the o2 sensor. The manifold also had a crack in it. Then my idle would go low sometimes. I replaced the manifold and the 02 sensor and I did get my check engine light cleared but there is still a problem. When I start the car it idles fine. But after driving it a little bit it idles really low. When I am in neutral and I hit the gas and let the idle go back down it goes down so low that I have had the car shut off but most of the time it goes as low as 100 or 200 RPMs. What is causing this? There is no check engine light right now but it still idles too low.
Old Aug 7, 2008 | 05:00 AM
Cypher0117's Avatar
Default Re: Idling problem (kuks24)
i think you should check your IAC valve. Also does it do this after it warms up or when the engine is still cold?
Old Aug 7, 2008 | 05:24 AM
aguon03's Avatar
Default Re: Idling problem (Cypher0117)
could be a number of things. But you would want to definitely check your IACV like my man above said. You might also want to look at your Throttle Position Sensor (TPS) and also make sure you dont have any air in your cooling system. Good Luck.
Old Aug 7, 2008 | 05:40 AM
kuks24's Avatar
Default Re: Idling problem (aguon03)
It only does it after it warms up. It idles fine at startup. Even if I run the car for awhile and then shut it off and start again. When I just start it it idles fine.
Old Aug 7, 2008 | 06:08 AM
kuks24's Avatar
Where is the IAC valve located in a 97 civic
Old Aug 7, 2008 | 06:36 AM
2fastek's Avatar
is it auto or 5 speed?
Old Aug 7, 2008 | 06:46 AM
kuks24's Avatar
5 speed
Old Aug 7, 2008 | 06:52 AM
kuks24's Avatar
Is there any way I could clean the valve or test it to make sure that is the problem.
Old Aug 7, 2008 | 07:59 AM
kuks24's Avatar
Are these hard to clean or easy?
Old Aug 7, 2008 | 10:28 AM
Irritated_Onion's Avatar
I've the exact same problem. Trying to address it currently.
Old Aug 7, 2008 | 10:31 AM
Lil_Wyte's Avatar
Default Re: Idling problem (Irritated_Onion)
here is a link to a great write up on cleaning it...
https://honda-tech.com/zerothread?id=1575913
Old Aug 7, 2008 | 11:21 AM
Default Re: Idling problem (Lil_Wyte)
Good write up, but these are 96+ cars. They have an EACV which has a rotary valve inside it.
The EACV is located in front of the throttle body, underneath the air cleaner, kuks24
Captain_Fook
Apr 10, 2014 03:24 PM
beef-cake
Jun 7, 2007 12:57 PM
champwhiteitr
Mar 17, 2004 03:39 PM
yoshio006
Dec 17, 2002 06:18 PM
B_1_8_hatch
Sep 10, 2002 06:44 PM
