Welding jet hot coated material?
Old Aug 6, 2008 | 05:02 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Welding jet hot coated material?
My current drag downpipe is jet hot coated up top, with a lighter coating down near the collector- I want to flair it out to 3", but am worried about welding on the jet hot coating as ive heard of issues with this- would I run into anything?
Or should I just get a simple U bolt and clamp the flair onto the downpipe to avoid welding all together? thanks!
Old Aug 6, 2008 | 05:15 PM
dave@passenger's Avatar
Default Re: Welding jet hot coated material? (nytosc)
If you want to weld it, you need to remove the coating both inside and outside.
Old Aug 6, 2008 | 05:43 PM
nytosc's Avatar
Default Re: Welding jet hot coated material? (dave@passenger)
wire brush attachment ona grider would work im assuming?
Old Aug 6, 2008 | 06:20 PM
It might, you would likely be better off using a sanding roll on a dremel IMO.
Old Aug 7, 2008 | 12:06 PM
TigWiz's Avatar
You are going to have a real hard time getting all the coating off if it was applied correctly, but it will all need to be removed. Especially if you plan to use a TIG, a MIG is less picky about the condition of the metal being welded.
Old Aug 7, 2008 | 01:02 PM
nytosc's Avatar
Default Re: Welding jet hot coated material? (TigWiz)
I may just use a U bolt and clamp the pipe down- keep hearing horror stories on how hard it is to get a good puddle going
Welding / Fabrication
Mar 30, 2012 08:45 AM
092eg6
10
Jan 14, 2011 08:21 AM
jacob4lester
Feb 16, 2010 09:31 PM
D15Bbigred
May 20, 2007 11:53 AM
VTECRXballa21
16
May 18, 2005 07:47 PM
