1998 Civic hatch DX: d16y7 auto SWAPED to d16y7 manual: has P1509
P1509 = Manf Cntl Veh Spd Idle Speed Control Auxillary Inputs
I did a tranny swap, y7 to y8 intake manifold swap, 3 wires to 2 wires IACV, changed ECU to manual one...
But I still have P1509 cel.
How do i resolve this?
PICS:
PICS:
If you are using that P2E ecu in the picture, than there was no need to swap to a 2 wire IACV. 96-98 CX, DX, LX all look for 3 wire IACV's. The only reason to use a 2 wire IACV is if you use a 96-00 EX ecu or any OBD1 ecu. Swap your ECU wires back and plug in your 3-wire IACV connector into the throttle body mounted IACV. Reset your ECU and that P1509 code should go away.
Ah i see. The P2E ecu is still looking for a 3-wire IACV. 2-wire IACV and 3-wire IACV sensors are not interchangeable even if you swap the wiring around. They both work in different ways.
Are you using a manual Civic CX, DX, LX P2E ECU?
-If yes, than it is looking for a 3-wire IACV sensor ONLY, located on the throttle body.
-If you are using any OBD1 ECU, B-series ECU, or manual OBD2 Civic EX P2P ECU, than it is looking for a 2-wire IACV sensor located on the back of the intake manifold.
-2-wire and 3-wire IACV sensor is dependent on the choice of ECU.
From your original post, it reads to me that you simply swapped from Auto to Manual with a Y8 intake manifold and a OBD2 Non-VTEC ECU.
If this is true, than there is no reason to go to a 2-wire IACV.
Put all of the IACV related wiring back to factory. Use your Y7 throttle body with the Y7 throttle body gasket (it will leak if you do not use a Y7 gasket). Plug in the 3-wire IACV connector to your 3-wire IACV sensor. Leave your 2-wire IACV on the back of the intake manifold and leave it unplugged. Reset your ECU and the code will go away and your IACV will be fully functional.
-If you do not wish to take off your Y8 throttle body, find your Y7 throttle body and unscrew the 2 phillips screws on the green 3-wire sensor. Pull the sensor off the Y7 throttle body, plug the sensor into your 3-wire IACV connector and zip tie it somewhere. Reset your ECU and the code will go away, but you will not have a functional IACV. It will most likely idle low when the motor is cold, but will run fine when it is warmed up.
whoa...what a minute im getting the same P1509
i have the 3 wire plug into the one by the throttle body and also theres the 2 wire plug on the other piece on the manifold
SO WHAT YOURE SAYING IS FOR ME TO ERASE THE CODE ALL I DO IS LEAVE THE 3 WIRE SOCKET PLUGGED IN AND THE 2 WIRE SOCKET UNPLUGGED??
how does that work? i dont understand. why would honda make it so that only one of these plugs has to be plugged in???
FYI i have EX body with D16Y7 swapped in running P2E 5 speed ECU
well i went and unplugged the 2 wire socket on the iac thing and tried erasing the code with my scanner and it came right back and then i unplugged the 3 wire one and left the 2 wire one in and tried and still CEL on WTF
i dont even know what to do anymore
rextoration
20
Jul 15, 2012 06:28 PM
blackbmagic
Sep 29, 2009 11:02 AM
TruSlydHatch
Aug 4, 2004 05:09 PM
