Alternator, Ground out, short out all worse at certain RPM?
Old Aug 5, 2008 | 01:35 PM
importdreamer's Avatar
Default Alternator, Ground out, short out all worse at certain RPM?
First off, it's an EM1 with about 103k on it. I have a perpetual CEL for a secondary o2 sensor.
I've noticed the CEL dims when approaching a stop on hotter than usual days. At around 2400 rpm when accelerating the light brightens back up. I thought it would be an alternator issue however, this doesn't happen all the time. I turned the lights on an off while sitting and the car doesn't bog down. There is a fluctuation but its not that noticeable. When I tap the brakes to make the taillights come on it makes the cel dim then immediately brighten up. Also, when I crank up the stereo further than usual the cel doesn't dim when the bass hits.
Is it more than likely a short out or ground wire issue in the lights?
Old Aug 5, 2008 | 02:23 PM
Default Re: Alternator, Ground out, short out all worse at certain RPM? (importdreamer)
Also there is no charge system light coming on while driving or stopped or anything.
Old Aug 5, 2008 | 03:01 PM
fastrc2's Avatar
i have seen where the main thick cable from the alternator about 4 to 12 inches away rubs through slightly on a bracket it touches or passes through, and when the motor moves to certain positions, it lowers vehicle voltage.
Old Aug 5, 2008 | 03:16 PM
Default Re: Alternator, Ground out, short out all worse at certain RPM? (fastrc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrc2 &raquo;</TD></TR><TR><TD CLASS="quote">i have seen where the main thick cable from the alternator about 4 to 12 inches away rubs through slightly on a bracket it touches or passes through, and when the motor moves to certain positions, it lowers vehicle voltage.</TD></TR></TABLE>
Would you recommend wrapping it or replacing it?
Yell0w
Honda Civic (2001 - 2005)
Nov 16, 2009 10:21 AM
rice is nice
May 25, 2008 09:43 AM
beana
Feb 18, 2008 01:34 PM
Eghatch93
Feb 1, 2006 05:52 PM
Blkcoupe
Dec 5, 2003 06:14 PM
