Hytech tri-y in a DA?
Old Aug 4, 2008 | 09:21 PM
Spanish_rice's Avatar
Default Hytech tri-y in a DA?
How much work does it take to get a hytech replica in a DA with b18a. Would i have to destroy the crossmember? Even if i install on a lift and come up from the bottom?
Old Aug 5, 2008 | 04:40 AM
icemangsr2's Avatar
Default Re: Hytech tri-y in a DA? (Spanish_rice)
you will have to notch the crossmember a lot, to the point that imho, is unsafe. get a set of traction bars. i recommend explicit speed performance. when i went to install my hytech, one could clearly tell how much would have to be cut out. not worth it.
also make a skidplate, or don't lower the car. the pipes will get destroyed.
Old Aug 5, 2008 | 05:10 AM
The G2 Racer's Avatar
Spoolin Performance is making a really nice header for the G2s, check it out: http://www.g2ic.com/forums/showthread.php?t=184247
Old Aug 10, 2008 | 09:27 PM
project dc2's Avatar
Default Re: Hytech tri-y in a DA? (The G2 Racer)
hit us up for that header !
NA4sho
Honda Civic (2006 - 2015)
Oct 3, 2006 08:13 AM
RallyRedGT-V6
May 11, 2004 02:13 PM
ultimatehonda
Jan 8, 2003 11:42 AM
RacerXintegra2k
Dec 31, 2002 09:39 AM
Ryuji
Oct 22, 2002 08:52 AM
