whos running a .82 a/r turbo ????
i would like to know how running a .82 a/r turbo on a b20
is it to laggy ???
what results ???
wheel hoop ???
what compression ???
is it recomendable for street usage??
im considering this set up gor my engine and i wana know who has gotten good results
thanks
is it to laggy ???
what results ???
wheel hoop ???
thanks
ok is a garrett 60-1 journal bearing turbo im looking between 380-420 hp range im considering the .82 a/r because i want to reduce wheel hoop but i dont want to suffer to much lag
thanks
Modified by eddie5141981 at 6:41 PM 8/4/2008
thanks
The 60-1 in a .82ar is a little large for your setup and power goals. You would do just fine with a .63ar and the proper setup to compliment it...hell, even a 57 trim would make that kind of power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralph11sec »</TD></TR><TR><TD CLASS="quote">gt30 with .82 here!
full boost at 5.7k!
Correct, even with the "R" series turbochargers, larger volutes can have different results generally in the same direction. It looks like he has the wrong turbocharger to begin with for his application. The turbine housing change is only 1/4 of the whole picture when picking out a turbo.
full boost at 5.7k!
</TD></TR></TABLE>Correct, even with the "R" series turbochargers, larger volutes can have different results generally in the same direction. It looks like he has the wrong turbocharger to begin with for his application. The turbine housing change is only 1/4 of the whole picture when picking out a turbo.
hi,
what could be the reason why people go up to 1.xx ar when they could have just go to the next bigger turbo,
say gt30 1.xx ar or gt35 .63AR. powerwise, and spoolup time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralph11sec »</TD></TR><TR><TD CLASS="quote">hi,
say gt30 1.xx ar or gt35 .63AR. powerwise, and spoolup time.</TD></TR></TABLE>
I believe I replied to your PM about this, but typically it is a bit easier on the turbine wheel to go up to the next size as opposed to what a lot of DSM guys do, and push their turbocharger several times past their efficiency points. GT30Rs in 1.06 A/R are very rare, and are really not necessary, especially in a street driven setup. The response would be terrible.
are you guys blind? the guy says he wants to switch turbo's because he suffers from WHEEL HOP. to the OP: forget the upgraded turbo. Buy the following. Solid motor mounts, front traction bar with torque mount, and then get and alignment. problem solved, your car will handle better, and you wont be laggy mcLaggerson
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx »</TD></TR><TR><TD CLASS="quote">built ls/vtec,20 psi, t4 60-1, 96 a/r backhousing, full boost 6500 with ls tranny.</TD></TR></TABLE>
are you serious ????
whats your rev limit 11,000 rpms
and what is your 1/4 mile time??????
full boost at 5.7k!
is that on the D-series in your sig ?
full boost at 5.7k!
</TD></TR></TABLE>is that on the D-series in your sig ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost »</TD></TR><TR><TD CLASS="quote">lsvtec t360-1 with stage 5 wheel and .82ar i get 12psi at 6100rpm</TD></TR></TABLE>
wow thats pretty bad in my opinion. you pretty much have an entire LS rpm band before full boost
