Drilling through firewall
I have a 92 Prelude SI, and I am trying to run my 2 gauge power wire through the firewall, and I can't find a spot to drill, does anyone have any suggestions?
if the wires you need to get past the firewall have to hook up to a positive 12V just hook it up to the headunits power instead of the battery. thats wat i did for my gauges. the wire is most likely yellow and it will probly have a lil fuse box on the wire
Remove the fusebox. There's room underneath.
Taken from a nitrous install at: https://honda-tech.com/zerothread/2261379
Also, remember to use a rubber grommet whenever running power wires through the firewall. Vibration and movement will rub the wire's insulation against the sharp chassis hole and it'll ground itself. Don't ask me how I know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twiztid00002 »</TD></TR><TR><TD CLASS="quote">if the wires you need to get past the firewall have to hook up to a positive 12V just hook it up to the headunits power instead of the battery. thats wat i did for my gauges. the wire is most likely yellow and it will probly have a lil fuse box on the wire</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geoffme »</TD></TR><TR><TD CLASS="quote">I have a 92 Prelude SI, and I am trying to run my 2 gauge power wire through the firewall, </TD></TR></TABLE>
2ga wire is pretty hefty, I'm assuming he's powering an amp with it.
Wow pics and everything. Considering the size of that line they used you should have enough room. Like said earlier dont forget the grommet!
Thanks everyone. =] The help is much appreciated =]]
and actually the 2g is just for now, I am hooking up 0g here soon I am running 2 1000 watt rms amps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2IntegraGS »</TD></TR><TR><TD CLASS="quote">Wow pics and everything. </TD></TR></TABLE>
Well, like they say: pictures are worth a thousand words. And since I didn't want to type out a thousand words, I used the vast resources of H-T to get the point across.
2,000 watts, good lord! Let's see this thing in action when you're done! How many subs are you running back there?
tim.simpson
Nov 16, 2008 12:23 PM
Jeff_G
Oct 5, 2002 05:41 PM
