Pilot bearing spinning inside flywheel?
Old Aug 3, 2008 | 10:10 PM
redman223's Avatar
Default Pilot bearing spinning inside flywheel?
I assume this is bad, as the manual says that the pilot bearing should be replaced if there is excessive wear or if it slips out of the flywheel easily. Thing is, this is a new pilot bearing, and the flywheel in question is a Clutchmasters aluminum flywheel, I believe it is around 8lbs or so.
Has anyone else had this problem? Does this mean the flywheel is done for and needs to be replaced? When I put the engine together about this time last year, the pilot bearing fit normally, meaning it had to be pressed in, but now it is way too loose.
Old Aug 3, 2008 | 11:43 PM
Ek9LbC's Avatar
Default Re: Pilot bearing spinning inside flywheel? (redman223)
bumpe
Old Aug 4, 2008 | 07:50 AM
redman223's Avatar
Default Re: Pilot bearing spinning or loose inside flywheel? (Ek9LbC)
I am sure others have had this issue, did you have to replace the flywheel? Did you notice anything weird when driving?
Old Aug 4, 2008 | 08:23 AM
superfast666's Avatar
Default Re: Pilot bearing spinning or loose inside flywheel? (redman223)
how do you know the pilot bearing is spinning
Old Aug 4, 2008 | 08:49 AM
redman223's Avatar
Default Re: Pilot bearing spinning or loose inside flywheel? (superfast666)
I took the flywheel out, and the pilot bearing fell out as soon as I turned the flywheel upside down. Then when I bought a new bearing, it did the same thing. When I first installed this thing last year it had to be pressed in, but now new bearings fall right in.
Old Aug 4, 2008 | 10:04 AM
hatchling37's Avatar
Yeah, that's bad. You might try a speedy sleeve. That's not ideal with something like this, but it might make your flywheel still operable. Other than that, I would suggest getting a new flywheel. Sorry
Old Aug 4, 2008 | 10:38 AM
redman223's Avatar
Default Re: Pilot bearing spinning or loose inside flywheel? (hatchling37)
Well that sucks, so much for Clutchmasters. I didn't even have that thing very long, used it maybe 3 years, and changed the bearing after 2 years of use, and at that time it still fit tight.
Old Feb 15, 2011 | 04:54 PM
biggishjay's Avatar
That's what she said...lmao sorry i had to
Old Feb 15, 2011 | 05:11 PM
racebum's Avatar
fidanza and exedy. if you go aftermarket get one of these two, both fit the task, the fidanza is the cheap way to go, like $150 shipped
Old Feb 15, 2011 | 08:34 PM
dr1ft@gious's Avatar
would this have anything to do with my thread?
https://honda-tech.com/forums/acura-integra-6/b20b-start-up-problem-2898720/
Steven Walters
Jan 16, 2017 07:06 AM
jdeemseerx
Oct 4, 2007 05:27 PM
skunkwhat
May 15, 2005 09:04 PM
JAYGSR
Oct 5, 2004 05:56 PM
RACESMART
May 7, 2004 09:24 PM
