flywheel question
Old Apr 30, 2004 | 03:56 PM
RACESMART's Avatar
Default flywheel question
what does it mean when the piolet bearing is loose in the flywheel?i took my flywheel out to have it cut and the bearing fell right out, shouldnt it be snug?, i had it pressed in, whats the problem,
Modified by RACESMART at 5:21 PM 4/30/2004
Old Apr 30, 2004 | 04:46 PM
Kendall's Avatar
It should be very snug. You should either have to hammer it in, or press it in. If it just fell out, then you obviously need a new pilot bearing.
Old Apr 30, 2004 | 04:49 PM
RACESMART's Avatar
Default Re: (Kendall)
i have a new pilot bearing , i also have a new clutch to put in, iyhe new one goes in with ease, seems like the bore on the flywheel is too big now, what could have caused this?
Old Apr 30, 2004 | 04:52 PM
Kendall's Avatar
A faulty bearing theoretically could have caused the flywheel to spin on the outer race rather than on the ball bearings, thus causing extreme heat and friction which, in theory, could cause the hole to enlarge.
Honestly, I have no idea exactly what caused it, but it's good that you got a new flywheel. I would have recommended one anyway.
Old May 1, 2004 | 07:38 AM
RACESMART's Avatar
any more ideas, the old bearing seems fine
Old May 1, 2004 | 07:48 AM
spaceman's Avatar
Default Re: (RACESMART)
did you get the correct parts?..make sure you do
Old May 1, 2004 | 10:41 AM
RACESMART's Avatar
Default Re: (spaceman)
yes they are the right parts
Old May 3, 2004 | 05:41 PM
RACESMART's Avatar
Default Re: flywheel question (RACESMART)
ttt
Old May 6, 2004 | 04:34 PM
RACESMART's Avatar
any other ideas
Old May 6, 2004 | 04:38 PM
doublejz's Avatar
possibly spun the bearing and made the hole in the flywheel too big now
Old May 6, 2004 | 08:31 PM
Billy Blaze's Avatar
Default Re: flywheel question (doublejz)
Your pilot bearing spun in the flywheel causing the hole to become to big. Just repalce the flywheel when you do the job. There pretty cheap. Or while your at it why dont you just go with an aluminum flywheel.
Old May 7, 2004 | 04:38 PM
RACESMART's Avatar
Default Re: flywheel question (Billy Blaze)
it was a fidanza flywheel, i just ordered a new clutchmaster flywheel,
Old May 7, 2004 | 09:24 PM
ACTman's Avatar
The flywheel was probably machined a little loose on the bearing diameter. If it is not too loose you can use a center punch on the center diameter in about 10-20 places and possibly a little Locktite and the bearing will stay just fine. If that sounds too mickey mouse for you, I know of a great flywheel that will fit perfect, hint hint.
Dxs
Transmission & Drivetrain
Apr 10, 2015 11:59 PM
sorta2
Jan 14, 2012 08:32 PM
redman223
Feb 15, 2011 08:34 PM
skunkwhat
May 15, 2005 09:04 PM
JAYGSR
Oct 5, 2004 05:56 PM
