integra stay revin a 1800rpm!help!
Old Aug 2, 2008 | 08:13 AM
dc2_916's Avatar
Default integra stay revin a 1800rpm!help!
http://www.youtube.com/watch?v=0lmxeOxLCtE this started happenin when i changed the throttle cable ..
Old Aug 2, 2008 | 05:14 PM
lmike6453's Avatar
Did you loosen the throttle cable? Common sense would be to loosen or disconnect the cable to see if that is the problem through process of elimination.
Old Aug 2, 2008 | 09:21 PM
Destructive-'s Avatar
Default Re: (lmike6453)
bro that is EXACTLY what mine is doing, im having the same problem i just posted about it "type r throttle cable install"
let me know if you get your problem fixed. ill hit you up also.
Old Aug 2, 2008 | 09:22 PM
JDM_CRX_PLEASE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">Did you loosen the throttle cable? Common sense would be to loosen or disconnect the cable to see if that is the problem through process of elimination.</TD></TR></TABLE>
same thing happend to my car but it was the gas pressure. the car use to have a built LSV in it then we put a stock b16a. the pressure was at 70psi. so it was buring lean and i never fixd it. didnt really care, car isnt mine anymore.
Old Aug 2, 2008 | 11:31 PM
dc2_916's Avatar
Default Re: (Destructive-)
got it fixed .. it was a vaccum leak on the throttle body gasket it was rip just a lil but i replaced it and it run fine now..
Old Aug 2, 2008 | 11:33 PM
Default Re: (dc2_916)
jord18
Apr 1, 2010 04:26 AM
Mr. Em1
Apr 21, 2007 08:23 AM
delamission
Jan 21, 2006 03:15 PM
LX4CYL
Feb 13, 2005 03:16 PM
GOLDBERG
Dec 24, 2003 02:11 PM
