speedometer broken but the problem isnt the speed sensor
hi this is a question on behalf of my boyfriend. he has a 90 honda accord. his speedometer doesnt work and he thought the problem was the speed sensor so he replaced it but it still doesnt work. he doesnt know what else to do or what might be the actual problem. any help?
Modified by imxyourxpassenger13 at 5:52 PM 8/4/2008
Modified by imxyourxpassenger13 at 5:21 PM 8/13/2008
Was the enitre tacomoter recently replaced?
If so, than he probably just needs to get it re-calibrated.
Even if he didn't recently switch out his tac, he still might just need to get a re-calibration done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mavvrik »</TD></TR><TR><TD CLASS="quote">Was the enitre tacomoter recently replaced?
Even if he didn't recently switch out his tac, he still might just need to get a re-calibration done. </TD></TR></TABLE>
Incorrect.
Swap the rear green circuit board on the back of the speedo in the cluster itself.
Incorrect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mavvrik »</TD></TR><TR><TD CLASS="quote">MuffinMan +1
Mavvrik -1
It's all good.
I bashed my head against a wall trying to figure out that fix
Mavvrik -1
</TD></TR></TABLE>It's all good.
im not sure if its tha circuitry on tha cluster because all tha rest of tha gauges are working perfectly fine tranny/engine light and sport light are still on
same problem here..
I have a 95 civic VX hatch. stock. guage does not read above 40mph on the hwy and sometimes it falls down to 20mph.
I get a check engine light 17 (VSS).
Replaced the VSS and the Speedo head.
Still problem exists.
Anyone share a similar story and how they fixed it?
my 1991 accord is missing the plastic that covers the speedometer/tac. so...my girl friend cleaned the meters and moved the speedometer needle now it isnt accurate how do i calibrate it i got it to work but not accurately.
I had a similar problem in my 94 Integra and I found the issue was corrosion in the wire harness itself. I ended up ghetto rigging 3 terminal ends after cutting out the wires from the VSS harness (was corroded beyond repair). May want to check the VSS harness to make sure you don't have the same problem. I hope this helps take one possibility off the list.
thanks i appreciate the feed back. my problem is that it worked flawlessly before she wiped a rag over the exposed speedometer. i think im on the way to a salvage yard for a cluster.
