**********HELP TRANSMISSION DOESNT SHIFT SMOOTH************
Old Jul 30, 2008 | 09:36 PM
luder916's Avatar
Default **********HELP TRANSMISSION DOESNT SHIFT SMOOTH************
I just did a tranny swapout on my ek and when the engine is not on the tranny would shift smoothly. When the engine is on I have to litteraly FORCE the transmission into gear. What can be the problem. I changed out the clutch, flywheel, pilot bearing, everything and used an alignment tool replaced the fluids with honda tranny fluid. Please help gotta try and finish by tonight. Thanks!
Old Jul 30, 2008 | 09:52 PM
Hanmin's Avatar
Bleed your clutch cylinder.
Old Jul 30, 2008 | 10:00 PM
luder916's Avatar
I already bleed it but will go back and do it again.
Old Jul 30, 2008 | 10:13 PM
doeboi365's Avatar
Default Re: (luder916)
u may need a new clutch master cylinder and a slave make sure no air is going in to the system too!!!
keep bleeding keep keep bleeding the clutch lol
but yea do that it should work make sure ur clutch pedal assembly bracket is still bolted to the fire wall to that was my problem i was missing one screw and i fixed everything big before going to that thats how air got into my system too it was pretty complicated but one screw the whole time kinda dumb i guess but ohhh well...
Old Jul 30, 2008 | 10:36 PM
luder916's Avatar
stupid question but what is the sequence of bleeding the clutch??? I know the brake, ie pump, pump, pump and hold then open up the brake cylinder and close after... is it the same? Do you need two people? I have a one man bleeding thing from autozone.
Old Jul 30, 2008 | 10:39 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder916 &raquo;</TD></TR><TR><TD CLASS="quote">stupid question but what is the sequence of bleeding the clutch??? I know the brake, ie pump, pump, pump and hold then open up the brake cylinder and close after... is it the same? Do you need two people? I have a one man bleeding thing from autozone.</TD></TR></TABLE>
it's done the exact same way.
Old Jul 30, 2008 | 10:50 PM
doeboi365's Avatar
Default Re: (Bense)
bro this is wat i did i had a
bottle under the slave and bleeder tube on the slave and crack the slave open.
now make sure ur clutch master cylinder is open before u do all of this and fill it all the way up with fluid that way no air will get in the system when that done jus start bleeding **** make sure the clutch cylinder does not go empty keep it filled up to the top after like 30 minutes cap the master up close the slave and pump the clutch repeat like 3 or 4 times keep a eye on the clutch master cylinder u dont want it to go down keep it up to level
Old Jul 30, 2008 | 11:11 PM
luder916's Avatar
HAHAHAHA, thanks for all the help!!!! Its done and I am back on the road again! HT to the rescue again! thanks to ALL!
Pinarr
Sep 10, 2012 11:14 AM
tegsallgood
Honda S2000
12
May 23, 2007 06:40 AM
94allmotor
Apr 16, 2007 06:26 AM
hspoon
Nov 20, 2006 10:38 AM
accord cd6 sir
May 25, 2005 06:27 AM
