How urgent is the idler bearing in the tranny?
Old Jul 30, 2008 | 03:32 AM
Patman's Avatar
Default How urgent is the idler bearing in the tranny?
Going to pickup a 93 today, 170k, new belts, new clutch for 950 today. LX with rusted quarters
It has the idler bearing issue and was wondering when it becomes a real problem if its mileage or by sound.
Old Jul 30, 2008 | 11:32 AM
Patman's Avatar
Seriously? Anybody?
What do these sound like, how often do they go out?
Old Jul 30, 2008 | 12:52 PM
blk92_d16's Avatar
Do you mean the throw out bearing? It's very common to hear the TOB or the Input Shaft Bearings on our Hondas.
If you can hear them, they usually need to be replaced.
Old Jul 30, 2008 | 12:54 PM
drtysohc's Avatar
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean the throw out bearing? It's very common to hear the TOB or the Input Shaft Bearings on our Hondas.
If you can hear them, they usually need to be replaced. </TD></TR></TABLE> +1
Throwout bearings are pretty easy to replace, but the input shaft bearing takes a little bit more work.
Old Jul 30, 2008 | 01:03 PM
Syndacate's Avatar
Default Re: How urgent is the idler bearing in the tranny? (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">Going to pickup a 93 today, 170k, new belts, new clutch for 950 today. LX with rusted quarters
It has the idler bearing issue and was wondering when it becomes a real problem if its mileage or by sound.</TD></TR></TABLE>
As others have said - are you talking about the throwout bearing?
Assuming you aren't, and you're talking about the idler bearing, as in the bearing that allows the idler gear to spin - it's very important if you want reverse in your car. That's if the gear doesn't jam and shred after the bearing ceases and the metal shards tear up the rest of your transmission. Though I don't think I've ever seen the bearing on the idler gear go bad...?
So which are you talking about - or since you seem a bit confused - what kind of noise is it making?
Old Jul 30, 2008 | 08:36 PM
Patman's Avatar
input shaft bearing I think, it almost sounds like lousy brakes/disc but the brakes were just "redone" on the car before we bought it and it stops great
a sliding/catching sound like a caliper is hung up but the car doesn't pull to one side and the sound is sporadic
I don't think its the throwout, I've done one on a mustang and my buddy does not have this issue with the clutch depressed.
What can I do to further diagnose the problem, thanks for all the responses thus far.
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
civic ef
May 29, 2012 01:02 AM
Pbanto
Apr 8, 2009 05:07 AM
Eklsv-t
Aug 28, 2008 10:52 AM
zman
Aug 22, 2004 08:41 AM
