how much psi on pump gas? 60-1
Old Jul 28, 2008 | 10:13 PM
patrick4588's Avatar
Default how much psi on pump gas? 60-1
sleeved turbo gsr. im running a 60-1 with .82ar housing and 1000cc injectors. im currently at 14psi and im bored with the power level. the tune is there to turn it up, im just wondering how high is safe on 93 octane. i was thinking about 18, but ive had some people say i should turn it to 22.
Old Jul 29, 2008 | 05:33 AM
sp00led's Avatar
Default Re: how much psi on pump gas? 60-1 (patrick4588)
You won't really know unless you make some passes and check your plugs. A good tuner will do this.
I just watched a K20a2 with a full-race kit 60-1 make 450whp at 18psi. They didn't push it any past 18psi on pump gas and i don't either with my built GSR / gt3076r.
Old Jul 29, 2008 | 07:34 AM
blackeg's Avatar
Default Re: how much psi on pump gas? 60-1 (sp00led)
i tuned my car with a t3 60-1 up to 18 psi on pump gas. it made 425whp but my afr was in the 10s above 7k rpms because the dyno wideband crapped out and i only had my in car one to go on. would have made about 440 with a moderately aggressive tune. btw motor is a 2.0l vtec b series
Old Jul 29, 2008 | 07:36 AM
JoePSI's Avatar
I think 18psi would be as high as I would go on 93 for daily driving. If you just want the Dyno sheet you could try to hit 500hp by turning it up a little higher, but I wouldnt keep it there for daily driving
Old Jul 29, 2008 | 07:39 AM
Scheizty's Avatar
Default Re: how much psi on pump gas? 60-1 (blackeg)
There is no general rule to the maximum psi. Your compression ratio and quench size also affect the likeliness of detonation.
Old Jul 29, 2008 | 08:12 AM
JoePSI's Avatar
Default Re: how much psi on pump gas? 60-1 (Scheizty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scheizty &raquo;</TD></TR><TR><TD CLASS="quote">There is no general rule to the maximum psi. Your compression ratio and quench size also affect the likeliness of detonation.</TD></TR></TABLE>
PSI is by no means a good measurement of engines durability level. Hes wanting a simple opinion though.
Old Jul 29, 2008 | 08:30 AM
sp00led's Avatar
Default Re: how much psi on pump gas? 60-1 (JoePSI)
pound for pound this turbo seemed to make about the same whp as my gt3076r. I assuming they are rated pretty similar.
TigerBallZ is the guy i'm talking about. He posts on here and has a clean EP3.
Old Jul 29, 2008 | 08:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI &raquo;</TD></TR><TR><TD CLASS="quote">
PSI is by no means a good measurement of engines durability level. Hes wanting a simple opinion though.</TD></TR></TABLE>
yeah just a ballpark. so basically like i said around 18psi is as high as i should go. thanks guys.
Old Jul 29, 2008 | 02:10 PM
Scheizty's Avatar
Although I have an h, not a b, I would not feel comfortable above 15psi on pump gas with a 9.5:1 ratio.
Old Jul 29, 2008 | 02:13 PM
Under_Pressure's Avatar
I have a 60-1 on my S2000 Ill let u know how much psi I get out of it.
Old Jul 29, 2008 | 02:25 PM
HamiltonRex's Avatar
Default Re: how much psi on pump gas? 60-1 (Under_Pressure)
I see 23-24psi on pump gas on my dsm, its a different animal but it is fine. This is with LITTLE water injection (50/50mix). Oh yeah and im not a typical dsm guys who love to run 30psi on little turbo's I started out with a boosted honda first.
goodluck.
Modified by HamiltonRex at 8:15 PM 7/29/2008
Old Jul 29, 2008 | 02:55 PM
TheShodan's Avatar
Moderator
For Hondas and DSMs, no more than about 19psi should be used based upon the CFM to Intake volume that this particular compressor wheel is able to give. The turbine wheel is a different story.
downeyballz
Oct 7, 2005 10:34 AM
fanta!
Jul 6, 2005 08:13 AM
DLB1994
Feb 23, 2003 05:27 PM
Screamer
Nov 8, 2002 05:37 AM
