what type of oil for 99 ex?
Old Jul 28, 2008 | 02:54 PM
slo gto's Avatar
Default what type of oil for 99 ex?
regular or synthetic?
5w30?
Old Jul 28, 2008 | 03:05 PM
iluvmy2000civicex's Avatar
Default Re: what type of oil for 99 ex? (slo gto)
I use Castrol Synthetic 10w-30 with a Fram filter. Cant beat it.
Old Jul 28, 2008 | 03:06 PM
Padawan's Avatar
Darth ModerVader
Conventional 5W-30 is fine.
Old Jul 28, 2008 | 03:20 PM
Default Re: what type of oil for 99 ex? (Padawan)
Yea just make sure you put the correct amount in it and change the filter with the oil change.
Old Jul 28, 2008 | 03:45 PM
slo gto's Avatar
Default Re: what type of oil for 99 ex? (iluvmy2000civicex)
3.5 qts for the 1.6L?
Old Jul 28, 2008 | 03:48 PM
BryanM.'s Avatar
Resident Gearhead
Yes 3.5 for the Y8/Y5, 3.8 for the Y7
Old Jul 28, 2008 | 03:58 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo gto &raquo;</TD></TR><TR><TD CLASS="quote">3.5 qts for the 1.6L?</TD></TR></TABLE>
Always double-check with the dip stick to ensure that you have the proper level. Don't just rely upon adding a fixed amount.
Old Jul 28, 2008 | 04:08 PM
MilanoRedEk99's Avatar
I use regular mobil 10w-30 oil in my 99 ex.
Old Jul 28, 2008 | 04:11 PM
Sr420Det's Avatar
Walmart has got 5 quarts of full syn for like 14 bucks, add a fram and your good to go
Old Jul 28, 2008 | 04:25 PM
itgrowsind's Avatar
Default Re: (Sr420Det)
Wow $14 is a good price
+1 Mobil 5w-30
Old Jul 28, 2008 | 04:42 PM
slo gto's Avatar
Default Re: (itgrowsind)
what is done from factory? synthetic or dino oil?
Old Jul 29, 2008 | 08:41 AM
slo gto's Avatar
bump?
Old Jul 29, 2008 | 08:49 AM
EGhatchguy's Avatar
Default Re: (slo gto)
do you have any leaks right now or any oil weeping on say the valve cover or anything? synthetic will leak worse than conventional oil because its generally thinner just something to take into consideration if all your seals are good then it would be better to run synthetic but regular 5w-30 should be good also
Old Jul 29, 2008 | 03:46 PM
Sr420Det's Avatar
So if I use 10w30 synthetic would it leak?
Billrey1967
Honda Civic (2006 - 2015)
Jun 9, 2008 06:01 PM
yujintheman
Feb 9, 2007 06:26 PM
kinkyintegra
Jul 23, 2006 11:56 AM
Jordans95si
Sep 2, 2005 07:45 AM
crazy eyez killa
Nov 15, 2003 05:32 PM
