Fan not working b20 motor on 98ex
I ned help. I got a b20 motor in my 98ex and the fan is not working, the guy that had before me had it wired directly into the battery. Does anyone know where is the temp. sensor located in those motors? What else can control the fan to kick in when it gets hot? Fuses are good by the way and the fan work sinse it was wired directly to the batt. Tahnks in advanced...
should be a fan switch on the thermo housing or the water pipe i believe its on the thermo housing find that plug use a paper clip bend it to fit in the plug to jump across if your fan turns on the fan switch is bad
phaphon
12
Sep 15, 2010 09:37 PM
