rear sway bar install, need help
Old Jul 28, 2008 | 10:29 AM
scottsopko320's Avatar
Default rear sway bar install, need help
ive got a 93 del sol si and am trying to finish off my suspension with a rear sway bar from eibach. but we all know that there is no factory sway on the del sol in the rear. so i was hoping someone could tell me which set of rca would work to bolt that bad boy on. ill be checking back all day till i get an answer. i need this bar on the car, the rear slides out on me.
here are some pics of the car!
Old Jul 28, 2008 | 10:38 AM
Eran's Avatar
HT White Ops
You need aftermarket RLCA's for a 92-95 Civic / 94-01 Integra.
Old Jul 28, 2008 | 10:39 AM
instructor74's Avatar
Default Re: rear sway bar install, need help (scottsopko320)
You can source lca's from any integra 94-01 they are a dir bolt on (they do have a bit of bend in them from the factory) So don't be shocked if you find ones in a salvage yard that look a little bent . I believe all the after market lca's have a place to mount sway bars. FYI if you are going to go anything over stock size sway bar you are really going to want to reinforce the sub frame with a brace. search for sub frame damage.
Old Jul 28, 2008 | 07:51 PM
thank you guys for the help, ill post pics of the install when i get it done. any specific brand of rca that i should be looking at?
Old Jul 28, 2008 | 08:41 PM
del_barry's Avatar
Default Re: (scottsopko320)
Del sol VTEC models had a rear swaybar
I'd try to source some OEM LCAs first
Old Jul 28, 2008 | 08:49 PM
OMGWTFBBQ!'s Avatar
You are aware that a sway bar won't stop your rear from sliding at all right? It only stops body roll and improves turn in, which will increase oversteer.
Old Jul 28, 2008 | 09:51 PM
yes i understand fully what the rear sway bar will do. thank you though. truly appreciate it!
Old Jul 29, 2008 | 12:55 AM
CapnKrunch's Avatar
Your car might handle better if you use the targa top
apetro94
Aug 4, 2015 01:53 PM
Mats_A_G
Sep 3, 2012 03:16 PM
GS8HFL21
Suspension & Brakes
11
Mar 27, 2005 10:36 AM
sol2nr
10
Feb 17, 2004 06:29 PM
