00 EM1: Removing Brake Caliper Pins
Old Jul 28, 2008 | 10:19 AM
Design's Avatar
Default 00 EM1: Removing Brake Caliper Pins
Hey All,
I'm in the proccess of servicing my brake pads/rotors and noticed the Caliper Pin A (lower Pin) won't go all the way in. I'm almost at 200K, so I think a little grease might do the trick. Is there any particular trick in pulling these out of the caliper housing? Any particular grease you might recommend using? Refer to #12 below. Thanks in advance.
Old Jul 28, 2008 | 10:42 AM
hatchling37's Avatar
Default Re: 00 EM1: Removing Brake Caliper Pins (Design)
Just pull. Use silicon grease
Old Jul 28, 2008 | 10:43 AM
1992Si's Avatar
THe pins should come out, you may need a 12mm socket.
Yes there is a grease made for that application. Any auto parts store has it. Wipe off the old stuff and put some grease on each pin, I also put a small dab in the sliders #13 to where the pads slide.
Put enough grease on the pins, you don't need a lot just enough. I'm sure you'll figure it out.
Old Jul 28, 2008 | 10:56 AM
Design's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">THe pins should come out, you may need a 12mm socket.
Put enough grease on the pins, you don't need a lot just enough. I'm sure you'll figure it out.</TD></TR></TABLE>
The bolt uses a 12mm socket, but the pin only has a tab on either side to pull. It just seems to be stuck in there rather tight. Thanks for the replies.
posHonda
Apr 16, 2007 04:42 AM
137
10
Sep 28, 2004 02:47 PM
FastNFurious
Mar 6, 2004 06:08 AM
Mike813
Sep 14, 2003 12:46 PM
nsxtasy
Jul 6, 2003 09:45 AM
