Mix Honda MTF and motor oil?
Old Jul 26, 2008 | 10:00 AM
randerson0248's Avatar
Default Mix Honda MTF and motor oil?
I can't believe that I am posting another MTF question!
I bought a 95 Del Sol about 6 months ago. It shifted very smooth.
2 Months ago I changed the trans oil. I put in 2 quarts of Honda MTF. Now it is no where near as smooth as before. It is accetable, but not as good as it was. Also, there is now a little more gear noise. Not much, but just a slight gear whine in the lower gears.
Has anyone used anything that they like better than Honda MTF? I wish I knew what was in the trans before I changed it.
I still have one quart of MTF left. I'm thinking that I might mix that 1 quart of MTF with one quart of motor oil and see how that works.
Any ideas or comments? Thanks.
Old Jul 26, 2008 | 10:02 AM
Sr420Det's Avatar
I use pure lucas oil stabilizer in my trannys.
Old Jul 26, 2008 | 10:49 AM
v8 integra's Avatar
Default Re: (Sr420Det)
bump for another mtf thread.lol help this man out!!!
Old Jul 26, 2008 | 11:03 AM
r33dm0n3y's Avatar
Default Re: Mix Honda MTF and motor oil? (randerson0248)
gm synchromesh. i had no reverse, flushed with 10w30...still no reverse, put in synchromesh...shifs like butter. this stuff really as amazing.
Old Jul 26, 2008 | 11:04 AM
quicksilver1689's Avatar
i ♥ snails
wow synchromesh did wonders for your tranny r33
Old Jul 27, 2008 | 04:49 PM
95whitehatch's Avatar
redline stuff is pricey but worth it if your having issues. In my 03 civic, 2nd gear wasn't smooth till I put that stuff in. I don't have easy access to it anymore
Old Jul 27, 2008 | 05:20 PM
user 98292739's Avatar
i have used Honda MTF, GM sycnromesh, Penziol Syncromesh, and advance auto 10w-30 all on the same y8 tranny
the cheap 10w-30 works the best. I was reading that the new honda mtf is way too thin for our trannies. Alot of people recommend just to use the 10w-30
Old Jul 28, 2008 | 07:58 AM
Default Re: (The Lobster)
I doubt the previous owner did any work or maintenance on the car himself.
So I would think that the if he ever had the trans oil changed, it was probably done by the local quick oil change place. They may have used motor oil in it.
So, I am going to try two things. One will be gm synchromesh and the other will be 10w-30 motor oil. As the post title says, I may also try half Honda MTF and half motor oil, since I have one quart of Honda MTF left.
Is there any place to get the gm synchromesh, other than the dealer?
Old Jul 28, 2008 | 08:13 AM
EG6 Love's Avatar
i work at a honda dealer and we pump normal 10w-30 motor oil in all the manual trannys
Old Jul 28, 2008 | 08:28 AM
THC07's Avatar
Default Re: (EG6 Love)
You only need one fluid in that tranny. All the people that say otherwise just dont know any better or had problems and blame the syncromesh. remember its the Friction Mod kind, and do not mix this with reg mtf
jdm702
Apr 15, 2010 04:50 AM
ptownsintegra
Sep 14, 2005 07:43 PM
SOHCMAN
Nov 4, 2004 08:06 AM
VtecDA9
Jul 29, 2003 02:35 PM
petrv
May 28, 2003 11:10 PM
