Cam seal/plug loosening & tightening sequence picture, dizzy oring
Old Jul 20, 2008 | 04:47 PM
ADerks12's Avatar
Default Cam seal/plug loosening & tightening sequence picture, dizzy oring
Hey i have a 5th gen lude with a h22a4, i have a Golden Eagle cam plug that i've been putting off changing for awhile. I will also be changing the dizzy o-ring. Anyways the DIY that i had bookmarked doesnt work anymore or the pictures dont work.
If anyone has the loosening and tightening sequence for the cam rail pictures that would be great. It has ft/lbs also on it. Any help or tips will be greatly appreciated.
I also have a DIY bookmarked for changing the dizzy o-ring but the pictures dont work either. I think it was for a Delsol, it was on honda-tech.
Where exactly do i draw a mark before taking the dizzy off? So i dont screw up the timing. Or is the prelude different then the delsol? I just dont want to take off the 3 bolts, change the o-ring then place it back together, and then the timing or something else is wrecked.
Any insight will be greatful thanks!
Old Jul 20, 2008 | 07:15 PM
ADerks12's Avatar
Also does anyone know much about taking the dizzy off to change the o-ring. I dont want to make another thread about it. Im just unsure of where to draw the line or if i need to.
In this DIY it shows what im trying to explain by drawing a line, but its on a different engine.
http://hondaswap.com/general-t...81866/
If anyone could clear this up that would be sweet.
Old Jul 20, 2008 | 11:05 PM
mkazm83's Avatar
Default Re: (ADerks12)
Find a Helms manual, it has all the specs. PM sent.
Old Jul 21, 2008 | 10:49 AM
95greenlude's Avatar
Default Re: (mkazm83)
get a timing gun....
Old Jul 21, 2008 | 11:40 AM
G2IntegraGS's Avatar
The line is draw just so that you can set your timing somewhere close to where it was. You really need a timing light. You need to make a line/scratch on the dizyy strait across to the head. That would be on the line close to the bottom of the picture.
Old Jul 21, 2008 | 12:31 PM
Eddiebx's Avatar
i dont think u need to makr ur timing on a 5th gen, the distributors are not rotatable.
Old Jul 21, 2008 | 03:56 PM
ADerks12's Avatar
well if the distributor on the 5th gens are not rotatable then i should be fine with just taking out the 3 bolts and pulling it out??
I also downloaded the helms manual, the chapters with the engine head and block. I found the specs that i needed for the cam plate.
Old Jul 22, 2008 | 09:50 PM
ADerks12's Avatar
So i was reading through the helms manual and found the instructions on taking the dizzy off. They note to before installing the dizzy back on to set piston #1 to TDC. Can anyone shed some light as to why i would have to do this?
Old Jul 22, 2008 | 10:00 PM
Si Speed's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">i dont think u need to makr ur timing on a 5th gen, the distributors are not rotatable.</TD></TR></TABLE>
You are correct.
Old Jul 26, 2008 | 03:32 PM
ADerks12's Avatar
Bump... Does anyone know why i have to be on TDC on Piston #1 to re-install the dizzy? To me it makes senses that if you take it off why couldn't you just put it back on without problem? Or am i missing the whole point to setting it to TDC?
Thanks again for your help so far, once I get this question answered im doing it.
Old Jul 27, 2008 | 10:51 AM
ADerks12's Avatar
bump
Old Jul 29, 2008 | 06:56 AM
imloggedin's Avatar
if youre worried about it. put it at tdc before you take it off.
danielblushtein
May 31, 2009 08:59 PM
4crx4me
Jan 7, 2006 02:39 PM
mickey513
Aug 8, 2004 06:39 PM
boi-alien
Aug 13, 2003 11:01 AM
Brolli007
Sep 9, 2002 06:27 AM
