Power Door Lock problem(not typical)
I start trouble shooting the power locks with the basics such as fuse, check connections, check relay box, and still nothing.
I grabbed the Helms Electrical manual (Thanks Ali)
After about an hour or more of following wires. I find the damn 12vdc power wire broke off the PIN connector on the Door Jam Harness. Anyone know if I can get a new pin and replace this?? or do you think I might need a new harness.
Your not going to find a pin like that in any local automotive store. It would probably be easier to buy another harness or another busted harness and steal a pin out of it. You can try to find the pin here but unless you know who makes the pin you probably won't find it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Henryx33 »</TD></TR><TR><TD CLASS="quote">I wish it was that easy, the pin is broken. The cable is long enough. I just cant find that type of pin at any local stores. Its frustrating.</TD></TR></TABLE>
Hit up the junkyard? EG ones are probably the same...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL »</TD></TR><TR><TD CLASS="quote">just go to the junkyard and cut that connector off another car and you will have all the pins you will need
That's most probably the best solution.
I still can't figure out how it would break like that in the first place, just my luck.
Anyhow, thanks for the input guys.
</TD></TR></TABLE>That's most probably the best solution.
Anyhow, thanks for the input guys.</TD></TR></TABLE>
Its because you have a turbo. Fix that problem and you'll fix all the problems.
Tell Katie I said hi.
wires always get pulled and kinked at that location far too often- especially some of the older EG's with power locks and windows- things start to magically stop working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 »</TD></TR><TR><TD CLASS="quote">Maybe you should ask one of the 6 previous owners. </TD></TR></TABLE>
How will that help him find a new pin and fix the problem?
not 100% sure, but you should be able to take the connector apart remove the pin, then reattach the loose wire again and good to go.. or get another harness from junkyard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
How will that help him find a new pin and fix the problem?</TD></TR></TABLE>
I think it was a joke, just like my joke about his turbo, even though my joke is also truth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Henryx33 »</TD></TR><TR><TD CLASS="quote">I got a few pins, i'll try them out tomorrow.
elaum why'd you sell the PIC parts?</TD></TR></TABLE>
I need to get my car fixed, and that gave me the money to do it. Accidents suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98DC2R »</TD></TR><TR><TD CLASS="quote">I just bought a door harness plug, sent you a pm
I got one, thanks anyway
</TD></TR></TABLE>I got one, thanks anyway
DJNauTicz
Dec 3, 2006 06:37 AM
99_EK9Civic
May 29, 2005 08:42 AM
