95 civic
Old Jul 19, 2008 | 10:51 AM
Seventy468's Avatar
Default 95 civic air conditioning questions please help
hey i am having some issues with my ac compressor clutch not engaging. The a/c hasnt worked since I was in a minor accident. What are some tests that I could do or maybe something i can look for? It is very frustrating to me to have little issues like this so any help would be greatly appreciated, thank you.
Modified by Seventy468 at 12:42 PM 7/19/2008
Old Jul 19, 2008 | 12:12 PM
Former User's Avatar
Default Re: 95 civic air conditioning questions please help (Seventy468)
Start simple by checking whether the fuse for the compressor clutch is blown.
Old Jul 19, 2008 | 01:16 PM
Seventy468's Avatar
Default Re: 95 civic air conditioning questions please help (RonJ@HT)
where is that fuse located
Old Jul 19, 2008 | 01:18 PM
1992Si's Avatar
http://hondatech.info/downloads/Auto/Manuals/
down load the manual.
Old Jul 19, 2008 | 01:20 PM
babyivan's Avatar
front end accidents = leaks(everything is up front).
Clutch wont kick on when freon is gone to protect the compressor.
step 1: check for leaks.... my shop runs this dye into the system and with a special light and some yellow goggles, can pinpoint it.
Old Jul 19, 2008 | 02:07 PM
Seventy468's Avatar
ok maybe i am making this harder than it should be, how can i check for a leak if the system is empty? the clutch isnt coming on at all right now, and from what i understood it wont take the refrigerant until its engaged.
Old Jul 19, 2008 | 03:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seventy468 &raquo;</TD></TR><TR><TD CLASS="quote">where is that fuse located</TD></TR></TABLE>
Fuse 13 under the dash. If the condenser fan runs, then the fuse is fine. In this case, get a manifold gauge set to check whether the refrigerant is low or gone before adding dye-containing refrigerant.
Old Jul 19, 2008 | 03:24 PM
1992Si's Avatar
Or take it some where and pay the man to fix it, or at least tell you what is wrong.
Old Jul 22, 2008 | 01:53 PM
babyivan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seventy468 &raquo;</TD></TR><TR><TD CLASS="quote"> ok maybe i am making this harder than it should be, how can i check for a leak if the system is empty? the clutch isnt coming on at all right now, and from what i understood it wont take the refrigerant until its engaged.</TD></TR></TABLE>
did you read my post?.... my shop puts this dye(harmless BTW) into the system to check for leaks.
Best bet is to take it to a professional to have it tested
Modified by babyivan at 5:58 PM 7/22/2008
Modified by babyivan at 5:59 PM 7/22/2008
AZCR-V
Honda CR-V & Element
Apr 23, 2018 07:58 AM
CrossCountry
19
Jul 7, 2016 06:03 AM
JNX
Honda Civic (2006 - 2015)
Jul 29, 2013 02:10 AM
jun10r27
11
May 28, 2011 08:47 PM
jdmcivicb16a2sc61
16
Mar 30, 2006 11:10 AM
