95 civic
95 civic air conditioning questions please help
hey i am having some issues with my ac compressor clutch not engaging. The a/c hasnt worked since I was in a minor accident. What are some tests that I could do or maybe something i can look for? It is very frustrating to me to have little issues like this so any help would be greatly appreciated, thank you.
Modified by Seventy468 at 12:42 PM 7/19/2008
Re: 95 civic air conditioning questions please help (Seventy468)
front end accidents = leaks(everything is up front).
Clutch wont kick on when freon is gone to protect the compressor.
step 1: check for leaks.... my shop runs this dye into the system and with a special light and some yellow goggles, can pinpoint it.
ok maybe i am making this harder than it should be, how can i check for a leak if the system is empty? the clutch isnt coming on at all right now, and from what i understood it wont take the refrigerant until its engaged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seventy468 »</TD></TR><TR><TD CLASS="quote">where is that fuse located</TD></TR></TABLE>
Fuse 13 under the dash. If the condenser fan runs, then the fuse is fine. In this case, get a manifold gauge set to check whether the refrigerant is low or gone before adding dye-containing refrigerant.
Re: 95 civic air conditioning questions please help (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seventy468 »</TD></TR><TR><TD CLASS="quote"> ok maybe i am making this harder than it should be, how can i check for a leak if the system is empty? the clutch isnt coming on at all right now, and from what i understood it wont take the refrigerant until its engaged.</TD></TR></TABLE>
did you read my post?.... my shop puts this dye(harmless BTW) into the system to check for leaks.
Best bet is to take it to a professional to have it tested
Modified by babyivan at 5:58 PM 7/22/2008
Modified by babyivan at 5:59 PM 7/22/2008
AZCR-V
Honda CR-V & Element
04-23-2018 07:58 AM
CrossCountry
19
07-07-2016 06:03 AM
jdmcivicb16a2sc61
16
03-30-2006 11:10 AM
