Your numbers with pump gas?
Old Jul 19, 2008 | 07:28 AM
garage16.ca's Avatar
Default Your numbers with pump gas?
Just wanted to know from others on what HP @ psi your car made with pump gas and also 1/4mile times with pump gas.
Old Jul 19, 2008 | 07:48 AM
turbodano's Avatar
Default Re: Your numbers with pump gas? (garage16.ca)
I made 585whp @21 psi on the Bullseye Power S368. That was through a ATI turbo 400 trans. 1997 Supra stock engine with cams and intake.
I have not been to the track yet.
Old Jul 19, 2008 | 07:56 AM
96 GSR-T's Avatar
I consider E85 "pump gas" as I pump it out of a gas station on a public highway, and it costs around what Gasoline costs.
585whp/385tq 23psi
Old Jul 19, 2008 | 08:54 AM
94turbosi's Avatar
430 whp pump gas ( STOCK B20 BOTTOM END ) only rod bolts first pass 11.10 @ 126 mph 2850 lbs vehichle with driver daily driven
Old Jul 19, 2008 | 09:15 AM
98civicswapped's Avatar
523whp 19psi t4 t67 daily driven
Old Jul 19, 2008 | 09:51 AM
CETVTOGEM's Avatar
Default Re: Your numbers with pump gas? (98civicswapped)
last year made 412@10psi 12.0@111
this year e85 ?hp@10psi 11.45@118
e85 @22psi 10.8@131
daily driver t4 67 p trim
Old Jul 19, 2008 | 10:50 AM
BoostR41's Avatar
Default Re: Your numbers with pump gas? (CETVTOGEM)
I made right around 450whp on pump 93 octane and 17psi. never ran it at the track on that boost
Old Jul 19, 2008 | 11:43 AM
nonvtecallmotor's Avatar
Default Re: Your numbers with pump gas? (BoostR41)
I made 485whp on 19psi 93 octsne 2-3 years ago. Went 11.5 on a 225 bfg.
Old Jul 19, 2008 | 11:54 AM
PhatS2000Turbo's Avatar
i made 456hp 329tq stock f20c 3mm headgasket 15psi.
Old Jul 19, 2008 | 08:21 PM
dester223's Avatar
Old setup with a straight LS in my 92 4 door civic LX. About 3 years ago.
91 octane pump gas.
~ 22 pounds on a PT67
10.8 @ 130
Old Jul 19, 2008 | 10:19 PM
blackeg's Avatar
Default Re: Your numbers with pump gas? (dester223)
425/286 @18 psi 84mm vtec motor
t3 60-1 using 93 pump from sunoco
Old Jul 21, 2008 | 06:08 AM
blueshark123's Avatar
Default Re: Your numbers with pump gas? (blackeg)
550 whp @ 21 psi on 93 octane
Old Jul 21, 2008 | 06:47 AM
integraboosted's Avatar
Default Re: Your numbers with pump gas? (blueshark123)
I made 561whp @24psi on pump gas.
Old Jul 21, 2008 | 01:21 PM
fukenricen's Avatar
490whp and 378whp 21psi ultra 94gas
garage16.ca
Feb 23, 2009 01:49 PM
LudeToAHatch
Dec 24, 2007 01:02 PM
a1320addict
Oct 15, 2005 12:46 AM
integlspwr2k
Aug 2, 2005 07:15 PM
