need answer ASAP...gsr axle in del sol hub...does it work?
Old Jul 20, 2002 | 04:20 PM
DC2_Jspec's Avatar
Default need answer ASAP...gsr axle in del sol hub...does it work?
my friend is swapping a gsr into a del sol. He is having problems with the gsr axle fitting the delsol hub or spindle or whatever it is called. Does he need a civic hub, or does it just take some finese to make it work with the del sol's? thanx
Old Jul 21, 2002 | 12:20 AM
buddha429's Avatar
Default Re: need answer ASAP...gsr axle in del sol hub...does it work? (DC2_Jspec)
it should fit right in.... mine has a gsr axle in a 93 hb and the setup came out of a del sol... it just has to slide in there... hope it helps, l8rz
Patrick Leist
May 6, 2017 09:45 AM
CKPerformance
14
Sep 12, 2007 10:54 PM
94projektsol
Sep 6, 2007 07:39 PM
KyleVA
Feb 17, 2007 07:02 AM
kay_animation
Feb 3, 2003 06:04 PM
