Gauge cluster went need help fast
Old Jul 18, 2008 | 09:05 AM
Lipan90crx's Avatar
Default Gauge cluster went need help fast
My 1990 CRX Gauge cluster went out also my turn signals, and reverse lights. None of my fuses are blown it has an LS swap in it. Is it something in the wiring or what I Would appreciate any help I can get surely someone has had thesame problem before.
Thanks
Old Jul 18, 2008 | 09:25 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Gauge cluster went need help fast (Lipan90crx)
you missed a ground wire.. or it came loose. Nothing causes widespread electrical failure better than a bad ground.
my guess is you either missed the ground on the thermostat housing or the engine ground on the valve cover..
Old Jul 18, 2008 | 09:27 AM
Lipan90crx's Avatar
Default Re: Gauge cluster went need help fast (sanimalp)
Thanks thats what i figured but wasnt sure since i didnt do the swap and all the wires were jacked up.
Old Jul 18, 2008 | 09:29 AM
Lipan90crx's Avatar
I havent had either of those Ground for a long time and it just went out. Could that still be the problem.
Old Jul 18, 2008 | 09:32 AM
sanimalp's Avatar
$cat /dev/urandom
yeah, if another existing ground went bad somewhere else and the system no longer has a good ground.. also, the lack of a ground could have fried all of that stuff over a period of time. that scenario is somewhat unlikely though. i would install all the ground wires according to the EF manual, and then re-evaluate the situation. you can make ground wires for cheap, and if it saves you haveing to get a different cluster and all that, it will be worth it.
Old Jul 18, 2008 | 10:11 AM
Lipan90crx's Avatar
True I have 1995 Civic parts car so i can probably rob the grounds off that
Old Jul 21, 2008 | 03:10 PM
Lipan90crx's Avatar
fixed my grounds still nothing
Old Jul 21, 2008 | 05:01 PM
hai_tech's Avatar
check ur relay
Old Jul 22, 2008 | 02:51 PM
Lipan90crx's Avatar
Default Re: (hai_tech)
all my relays are good
TravisB16a
May 16, 2008 05:27 PM
Dense
10
Jan 2, 2008 07:46 PM
Mister Jew
Sep 22, 2006 05:55 PM
court
12
Apr 24, 2006 06:25 PM
B18C1EF
12
May 31, 2005 04:49 PM
