Shifting Problem
For some odd reason when i was driving along, my shift stick came out of 2nd and now 3rd gear won't work. I had this 95 civic for 5 years now and this is the first trouble. When i drive, 1st and 2nd works; 3rd doesn't, 4th and 5th is fine. So when i drive, i jump to gear 4.
Anyone know the problem of this; most likely its the transmission. But anything else? clutch, shift linkage, etc? any help will do. It's a d15 motor by the way.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EX_Civic »</TD></TR><TR><TD CLASS="quote">shift fork in you tranny, or syncrhos.</TD></TR></TABLE>
If it was the fork he'd most likely have trouble with 4th too, though it's still possible.
@ OP: It's most likely your syncros - '92-'00 civics are known for their 3rd gear syncros going out prematurely (or prematurely in terms of the rest of the engine/trans).
It's kinda known as the "honda 3rd gear grind" and 9 times out of 10 it's your syncros.
Rip that trans apart & rebuild time.
EDIT:
In the meantime to save wear on the syncros you might wanna double clutch into 3rd.
EDIT:
I agree!
Synchro...
I haven't run across this with my Hondas - but had the same problem with a Borg-Warner T10P tranny - cracked 3rd gear synchro...
Matter of fact, from a dead stand-still, I could put it in 3rd gear - slowly engage the clutch - and it would pop out of gear. LoL!
Modified by BlackDeuceCoupe at 1:11 PM 7/20/2008
Synchro...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
EDIT:
In the meantime to save wear on the syncros you might wanna double clutch into 3rd.</TD></TR></TABLE>
What does it mean to double clutch?
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rSol93 »</TD></TR><TR><TD CLASS="quote">
What does it mean to double clutch?</TD></TR></TABLE>
if i remember correctly.... while in gear, press the clutch in, put into neutral, release clutch, press clutch in again, and put into next gear. correct me if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 »</TD></TR><TR><TD CLASS="quote">if i remember correctly.... while in gear, press the clutch in, put into neutral, release clutch, press clutch in again, and put into next gear. correct me if im wrong</TD></TR></TABLE>
No, you're right!
You gotta do this with diesel trucks, etc - vehicles that don't have synchros.
Sometimes you gotta do this when your Honda tranny is cold, and it won't go into 1st gear during a slow roll, yada, yada, yada.
The thing is, if you keep trying to force it into 3rd gear - you really ARE gonna bend a fork!
I'd 'nurse' it until I had a chance to repair/replace the tranny, but that just me...
No, you're right!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mmmeecho »</TD></TR><TR><TD CLASS="quote">Thanks guys! I guess ill get a new tranny or maybe a new b series engine.
lol</TD></TR></TABLE>
B16s rock!!!
Check out the FE on my B16A2 swap...
160+ HP & 40+ MPG
lol</TD></TR></TABLE>B16s rock!!!
160+ HP & 40+ MPG
It's not necessarily the tranny...could just be the clutch. This happened to be recently, so I couldn't access any gears...
http://img244.imageshack.us/im...1.jpg
BULL3TPR00F
Feb 14, 2012 10:00 PM
Jaydeep
Dec 22, 2009 08:38 AM
snatch
Jul 1, 2004 07:01 PM
