need help surging issue
Old Jul 17, 2008 | 06:49 PM
mg40's Avatar
Default need help surging issue
need help!! surging issue
already replaced the following parts:
coolant temperature sensor(new)
throttle body w/ map,tps,icv(used)
tune up stuff:fuel filter,spark plugs,etc.
throw me some ideas car gods pls...
the car is 96 civic hb w/d16y7
Old Jul 17, 2008 | 06:59 PM
Former User's Avatar
Default Re: need help surging issue (mg40)
Clean the used IACV and bleed the cooling system of trapped air.
If still no satisfaction, check for vacuum/intake air leaks. Look for loose or disconnected hoses leading to the intake manifold. Spray carb cleaner around connections and gaskets while engine is idling -- a change in idle speed would indicate a leak.
Old Jul 17, 2008 | 07:06 PM
mg40's Avatar
Default Re: need help surging issue (RonJ@HT)
will do tomorrow thank u
liljukmoves
18
Jun 26, 2011 07:18 AM
KILLAB17VTEC
Nov 12, 2009 02:02 AM
JDM.K24
Oct 16, 2009 07:07 AM
Famous94LS
Apr 16, 2009 06:34 AM
asianrepnsb
12
Mar 8, 2008 12:26 PM
