00 SI gas mileage question
Old Jul 17, 2008 | 02:23 PM
tekniq's Avatar
Default 00 SI gas mileage question
so i got my 100k service done, and the mechanic was talking to me and he asked me at waht RPM i shift at when switching gears. I told him I shift at about 2-2.5 when i try to save some gas, but he told me that the SI has the best gas mileage when shifting at 3.5-4k RPMs because our cars were made to shift at higher gears and it causes less stress to the engine when shifting a little before vtec hits. I asked him how he knew that, and he told me his friend did his paper to graduate from auto-school on peak gas mileage on the integra, and he did dyno tests and he found that gas mileage is indeed best when shifting at 3.5-4k rpm. so my question to you guys is, does this sound any correct to you?
Modified by tekniq at 6:35 PM 7/17/2008
Old Jul 17, 2008 | 03:12 PM
NOFX's Avatar
H-T White Ops
It'd be different for each car. What's best for the Integra might not be best for the Civic.
Old Jul 17, 2008 | 03:34 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: 00 SI gas mileage question (tekniq)
I'm running a '99 Si B16A2 - and get 41 MPG give or take... so take this for what it's worth...
I basically agree with your mechanic. I never shift at 2000-2500 RPM unless I'm in a parking lot, bumper-to-bumper traffic or whatever.
3000-3500 RPM *seems* about right to me, all things considered...
Old Jul 17, 2008 | 03:44 PM
SFBPI504's Avatar
Default Re: 00 SI gas mileage question (BlackDeuceCoupe)
i dont get 41 mpg in my 00 si but i shift at 2500 and i get 30-31 mpg on average and 27-28 mpg when i shifted 3500 and i wrote down each time i filled up and filled up exactly till it clicked so for mine i found shifting at 2500 was best for my car
Old Jul 17, 2008 | 04:06 PM
Mingo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">so i got my 100k service done, and the mechanic was talking to me and he asked me at waht RPM i shift at when switching gears. I told him I shift at about 2-2.5 when i try to save some gas, but he told me that the SI has the best gas mileage when shifting at 3.5-4k RPMs because our cars were made to shift at higher gears and it causes less stress to the engine when shifting a little before vtec hits. I asked him how he knew that, and he told me his friend did his paper to graduate from auto-school on peak gas mileage on the integra, and he did dyno tests and he found that gas mileage is indeed best when shifting at 3.5-4k rpm. so my question to you guys is, does this sound any correct to you?
Modified by tekniq at 6:35 PM 7/17/2008</TD></TR></TABLE>
interesting
Old Jul 17, 2008 | 04:58 PM
tekniq's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">It'd be different for each car. What's best for the Integra might not be best for the Civic.</TD></TR></TABLE>
i asked him same thing...he said it's the same
Old Jul 17, 2008 | 05:07 PM
NOFX's Avatar
H-T White Ops
Default Re: (tekniq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">i asked him same thing...he said it's the same </TD></TR></TABLE>
I call bs then. They have different transmissions gear ratios.
Old Jul 17, 2008 | 05:17 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (NOFX)
I call bs then. They have different transmissions gear ratios.</TD></TR></TABLE>
Yes they do. A slow roll up to 3500 +/- rpm then shift gives me the best mpg with my EH2 B16A, 'bout 38 mpg using 93 oct. Slow acceleration is key for good mpg.
Old Jul 17, 2008 | 06:01 PM
HT White Ops
Default Re: (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">A slow roll up to 3500 +/- rpm then shift gives me the best mpg with my EH2 B16A... Slow acceleration is key for good mpg.</TD></TR></TABLE>
Heh!
Thank you!
Besides - you'd be roadkill if you shifted at 2500 RPM around here...
Old Jul 17, 2008 | 06:04 PM
turbojdmhatch's Avatar
Yes they do. A slow roll up to 3500 +/- rpm then shift gives me the best mpg with my EH2 B16A, 'bout 38 mpg using 93 oct. Slow acceleration is key for good mpg.</TD></TR></TABLE>
no kidding ur ecu wont read it as u tryin to accelerate fast and dump more fuel into the motor...if ur full throttle..shift...full throttle...shift even tho ur only goin up to 3 grand and shifting ur still gonan get shitty gas mileage
Old Jul 17, 2008 | 06:23 PM
MegaPower's Avatar
i got 31 when i am shifting at 3000rpm and hell slow accel
I got 29 when i am shifting at 3500-5000
HJNDDMCVCSi
Honda Civic (2006 - 2015)
Mar 7, 2009 03:21 AM
Civic_07
Mar 11, 2008 04:28 PM
Emberghost
Apr 26, 2005 06:16 AM
JDM_Type-R
Mar 12, 2002 11:06 AM
