did a compression test on my gsr today and the results were low.
90's all across.......i motor starts and runs fine, so i was wondering if the motor was bad with bad rings would it start at all and run?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out »</TD></TR><TR><TD CLASS="quote">something is wrong with your compression tester.</TD></TR></TABLE>
i think so too...its the cheap **** from auto zone.....what would you recommend me doing when i do the compression test.... that **** runs like a charm....it smoke a lilttle bit here and there but im guessing its the valve seal. it doesn't smoke like all the time.
compression tester is junk more than likely
i had the same problem with a cheap *** one i bought , the motor had good compression the previous year so i knew something was up
yeah same here so i was really hurt seeing the numbers.......lolz....if i know how to post pictures i woudl show u guys my turbo gsr del sol
it was a messed up gauge that gave such a low reading... 180 and 190 all across....i guess all i need is to send out my head and change all the seals..
Nextelbuddy
Jan 9, 2004 06:18 PM
