dropped shifter
Old Jul 12, 2008 | 03:11 PM
92VXeg's Avatar
Default dropped shifter
i dont know how and i dont what happened it just seemed lower while driving it earlier today and now i can hit my exhaust pipe with the shifter. Does anyone know what the part number is off hand. or a pic?
It an Ls in an eg hatch.
I drove on it for about 15mins. I guess it wount hurt anything until i can get the part to fix it. Someone correct me if im wrong
Old Jul 12, 2008 | 03:17 PM
Thateguhate's Avatar
Default Re: dropped shifter (92VXeg)
my guess would be you lost a bolt to your shift linkage... Take off the boot and see whats going on under there. Should be a simple fix though...
Old Jul 12, 2008 | 05:02 PM
itsmejto's Avatar
sounds like the rubber mount under the shifter broke loose.
you may need this. Jack up the car take a look, its right on the end of the support rod under and to the back of the shifter. Held on with two 6mm bolts with 11mm heads..
http://cgi.ebay.com/ebaymotors...sting
Old Jul 12, 2008 | 05:30 PM
thumper64's Avatar
That's about the only thing that could cause your shifter to hit the exhaust.
Definitely get the new bushings that itsmejto linked to. Even if it doesn't fix your problem, you'll be glad you put it on.
Old Jul 12, 2008 | 10:39 PM
92VXeg's Avatar
yea i lost the two bolts...
it was hard at first to figure out what i lost since it wasnt there and i dont know every part in the shift linkage but thanks for the link and it will be back to new as soon i can get it. thanks
ERKK
Mar 7, 2009 09:25 AM
BSERIEuS
Aug 25, 2005 09:07 AM
sohctodohc
Oct 3, 2004 06:43 PM
IntegraBoy04
Aug 13, 2003 12:40 AM
BAZ
Jul 29, 2003 09:29 PM
