How do you guys feel about Motec?
Old Jul 11, 2008 | 07:11 AM
hispanic panic's Avatar
Default How do you guys feel about Motec?
What exactly is motec capable of? I'm gonna be tuning the ecu myself this time instead of having someone else do it, and i'm not too experienced with tuning so ease of tuning is kinda important. How extensive is the datalogging? I'd need to monitor 3 different pressure sensors, egt, 2 diff flow sensors, and other usual stuff.
Can i tell it to maintain a certain afr for certain rpm ranges and just run it to redline a few times and it'l;l tune itself?? lol
Old Jul 12, 2008 | 10:50 AM
Top Ramen's Avatar
Default Re: How do you guys feel about Motec? (hispanic panic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hispanic panic &raquo;</TD></TR><TR><TD CLASS="quote"> i'm not too experienced with tuning</TD></TR></TABLE>
Motec is not a system to learn on. If you had provided some information about your motor, we could probably recommend a better 1st time system. For example, Neptune is relatively easy to set up and even a beginner can build a base map that will have the motor fire up and idle just fine.
Old Jul 12, 2008 | 07:58 PM
sander's Avatar
2.7(p/t)
AEM is a better choice for you.
And yes, AEM has automapping.
With a universal harness, and only the most basic features for an M400 you will be in the 4500.00 range.
Old Jul 12, 2008 | 10:59 PM
alpha's Avatar
MoTeC is a great system and software capable of just about anything. If you have little to no tuning experience MoTeC is definately the wrong system to be learning on. What application/car is this for?
Old Jul 14, 2008 | 06:52 AM
Bisimoto's Avatar
Default Re: How do you guys feel about Motec? (sander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander &raquo;</TD></TR><TR><TD CLASS="quote">AEM is a better choice for you.
With a universal harness, and only the most basic features for an M400 you will be in the 4500.00 range.</TD></TR></TABLE>
AEM all the way! Very cost effective as well...with a myriad of useful features.
Old Jul 18, 2008 | 12:51 PM
Default Re: How do you guys feel about Motec? (alpha)
Its for a 600cc f4i. I had to rip off the ITB's and make an intake manny for it.
Automapping features are great. I would probably preffer some automapping stuff. I'll also have access to a dyno.
Old Jul 18, 2008 | 04:23 PM
h22 civic's Avatar
Default Re: How do you guys feel about Motec? (Bisimoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">
AEM all the way! Very cost effective as well...with a myriad of useful features.</TD></TR></TABLE>
Old Jul 18, 2008 | 08:49 PM
turbociv910's Avatar
f4i, as in a motor cycle?
We put a motec m4 on a turbo snow mobile. Needles to say it was fast as hell.
Motec is not a easy system to learn, even most well known tuners do not do motec, or charge a rediculous ammount to tune it. Its not so much tuning that is hard, but wiring it up, calibrating everything can be time consuming.
Old Jul 19, 2008 | 07:24 AM
baller status's Avatar
Let me ask you this: can you build a VE table? Do you know how to set coil dwell? Or injector offset? Battery offset?
Get the AEM. It plugs in with almost no wiring changes. It has base maps. It's cheaper. It's user friendly.
Automapping sucks by the way. It makes a mess of your fuel map. It adjusts one particular cell and ignores neighboring cells. There are several ways I recommend tuning fuel. One is to make passes on a dyno and make changes to groups of cells. Get it into the neighborhood. Then make changes according to datalogs. Then you can have a friend drive it around on the street while you tune it. The last two strategies require a wideband O2.
Fuel is only half the battle. There's also ignition. And if it's a daily driver you can spend months on the idle. Not to mention transient fuel and sensor based fuel trims. Then there's start up.
Old Jul 21, 2008 | 01:52 PM
hotimportcrx's Avatar
Default Re: How do you guys feel about Motec? (baller status)
Well, hector just came into Harry's and ordered 3 t66 turbos with Spoon engines and a motec system exhaust.
Old Jul 21, 2008 | 01:54 PM
Default Re: How do you guys feel about Motec? (hotimportcrx)
Lol, sorry i had to. I would just get an Aem stand alone. Its cheaper and does the job, IMO, just as well as any other stand alone on the market.
Old Jul 21, 2008 | 06:53 PM
Turbo-charged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">Lol, sorry i had to. I would just get an Aem stand alone. Its cheaper and does the job, IMO, just as well as any other stand alone on the market. </TD></TR></TABLE>
its cheaper. i'll give you that
Old Jul 21, 2008 | 08:19 PM
i dont know how to, but thats why i pay my tuner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller status &raquo;</TD></TR><TR><TD CLASS="quote">Let me ask you this: can you build a VE table? Do you know how to set coil dwell? Or injector offset? Battery offset?
Fuel is only half the battle. There's also ignition. And if it's a daily driver you can spend months on the idle. Not to mention transient fuel and sensor based fuel trims. Then there's start up.</TD></TR></TABLE>
Old Jul 21, 2008 | 08:30 PM
alpha's Avatar
Default Re: How do you guys feel about Motec? (turbociv910)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv910 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how to, but thats why i pay my tuner
No worries. I'm 99% sure he was replying to the original poster
Old Jul 21, 2008 | 08:46 PM
woops.. sorry baller status.. thought you were talking to me
Old Jul 30, 2008 | 07:28 AM
yes the f4i is a motorcycle. Do you guys still reccomend AEM now knowing that the f4i is a motorcycle?? People seem to be assuming this is a car with a passenger seat. Its a motorcycle engine, and it will only see racing. No daily driving, but i will still need a good tune for neutral power throttle positions and the like.
I'd prolly be working with a tuner also. so the consensis is still aem??
jdm_vtec
Jan 28, 2008 01:55 PM
Vtakkk
May 30, 2006 08:56 AM
a1320addict
Dec 9, 2004 09:07 AM
aut0tek
51
Aug 11, 2004 10:23 AM
11psiTurboSI
Nov 9, 2003 07:14 PM
