How do I change out my shift boot?
Old Jul 11, 2008 | 05:29 AM
IMHARD2's Avatar
Default How do I change out my shift boot?
I just recently bought an ITR shift boot for my lude, but don't know where to start to take it apart...Does anyone have any knowledge or links for me? Thanks
Old Jul 11, 2008 | 08:42 AM
donger's Avatar
Default Re: How do I change out my shift boot? (IMHARD2)
If this is for a 4th gen, then here are the directions.
Remove shift ****. (If stock, pull down shift boot away from ****, then twist of ****)
Take off the screws on the center console(4 on driver's side, 4 on passenger's side, 2 above the stereo).
Carefully pull up center console and remove (You may have to move shifter)
Two screws hold the shift boot frame onto the center console, remove those.
You're gonna have to remove the staples that hold the boot on the frame, and then restaple your new boot onto the same frame. Then reverse the directions for install.
Old Jul 11, 2008 | 08:18 PM
ricoMugenlude97's Avatar
Default Re: How do I change out my shift boot? (donger)
If it's for the 5th gen, it's the same thing. squeeze the sides of the shift **** where it meets the shift boot. Unscrew the ****. Remove the screws that hold the center console in place and flip it upside down. unscrew the shift boot frame plate and remove the staples. staple the new one on and then everything else is the opposite of removal.
Old Jul 11, 2008 | 10:54 PM
InvaderTrax's Avatar
When I did mine, the staples kept coming loose, so I ended up using pop rivets. 2 or 3 and it hasn't budged since
Old Jul 13, 2008 | 05:16 AM
ethereal2pt2's Avatar
Default Re: (InvaderTrax)
i just used needle nosed pliers to pull put and put back the original staples. i bent back the ends to secure it back onto the shift assembly. hasn't budged at all. you gotta make sure to give it enough slack or else 3rd and 4th will be a tight fit.
edit: i used a clamp to secure the top end of the shift boot directly under the shift **** so every last part counts in terms of length. i ended up having to readjust the shift boot to allow for more slack.
Old Jul 13, 2008 | 07:52 AM
_interLude_'s Avatar
Default Re: (ethereal2pt2)
are u using industrial staples?
Type-Spaz
Nov 28, 2012 05:22 PM
red98integra
Dec 17, 2008 10:33 PM
speedeGdc2
Mar 17, 2008 10:19 AM
siaemsi
Apr 8, 2004 11:54 AM
LudemanDan
Jun 1, 2002 12:51 AM
