overheating problems on gsr motor.
Just put my build together and having alot of problems with the motor overheating.
The radiator keeps throwing water out and if i drive about 15 miles i have to put about 1/2 a gallon or more of water in it.
i replaced the headgasket and reshaved the head but it was still over heating especialy once i put the car over 5k rpm.
now i am being told that its the block. they said the sleeves on my block are not even and are off by a couple milimeters.
would shaving the sleeves to make them even work?
Heres some specks on my motor.
block done by jg. 86mm pistons, jg open deck sleeves, rods etc.
head- port polish, toda spec c cams, valve springs retainers, etc.
rmf headers, type r tranny, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dean_mcl »</TD></TR><TR><TD CLASS="quote">
If your block is truly warped a couple of mm you definately need to get it decked.
rmf headers
</TD></TR></TABLE> You have more then one?
Honestly, does the fan turn on? Stock fan switch? If not, air pocket buy the item below!
Lisle Automotive Spill Proof Funnel!
rmf headers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">
If your block is truly warped a couple of mm you definately need to get it decked.</TD></TR></TABLE>
I have a hard time buying that you have sleeve variation by 2mm, thats .080 you could see that with the naked eye. and wouldn't that variation create some evident cross contamination?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dean_mcl »</TD></TR><TR><TD CLASS="quote">i have koyo half size radiator and the fan switch was rerouted so the fan stays on constantly when the car is on</TD></TR></TABLE> Ya not a fan of single pass down flow tiny radiators. I have money on an air pocket though regardless.
been through about 3 headgasket and just ordered anorther one. engine is on its way to the machine shop everything will be resurfaced head and block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Was the headgasket you removed blown? </TD></TR></TABLE>
I didn't catch the gasket thing. Good question.
Good luck to the OP on this headache.
I didn't catch the gasket thing. Good question. Good luck to the OP on this headache.
