What would cause erratic map sensor readings? Bent valve maybe?
Old Jul 8, 2008 | 07:21 PM
brokenojoke's Avatar
Default What would cause erratic map sensor readings? Bent valve maybe?
After my dyno tune at which we took my B16a to 9,500rpm a couple times (built head), I don't get any vacuum at idle anymore. Used to idle at 288mbar, and now it fluctuates between 400-600mbar. And then after it warms up, it will dive even below what it used to idle at, and then shoot up to 700mbar with the throttle closed. Makes it damn near impossible to drive.
I checked for vacuum leaks by spraying brake cleaner around intake manifold and all vacuum lines. No surge in rpm. I also checked all the manifold bolts, throttle body bolts, IAT sensor screws. All were tight.
I moved the cam gears at the tune, but nothing crazy. +4 intake -3 exhaust.
Old Jul 9, 2008 | 12:27 AM
mtber's Avatar
Default Re: What would cause erratic map sensor readings? Bent valve maybe? (brokenojoke)
Complete a compression & leak down test :-)
Old Jul 9, 2008 | 06:20 AM
Default Re: What would cause erratic map sensor readings? Bent valve maybe? (mtber)
Damn you and your logic.
Will do. I'm just expecting the worst so I figured I'd ask.
Old Jul 10, 2008 | 08:57 AM
blundar's Avatar
massive vacuum leak / blown throttlebody gasket / blown IM gasket / fouled plugs
(little less severe)
93SiPrelude
Feb 24, 2008 10:39 PM
GaRn
May 20, 2004 09:29 AM
paul93sir
Feb 5, 2004 11:26 AM
Projectg2i
Jan 12, 2003 01:21 PM
ITR1071
May 26, 2002 11:37 AM
