power windows dont work but power locks work. need help.
Old Jul 7, 2008 | 01:13 PM
solsi2000's Avatar
Default power windows dont work but power locks work. need help.
On my 94 del sol i was trying to wire up a map light on the passenger side door panel. I was trying to tap power from one of the 3 orange wires that plug into the window switch thats attached to the door panel. Anyways I could not get power from them even with a voltmeter I only see .14 volts and its not constant. So i put everything back the way it was and now none of my power windows work. But my power mirrors work just fine from the panel. I checked all the fuses and they seem fine too. Anyone know what else to check for? Thanks in advance!
Old Jul 7, 2008 | 03:18 PM
solsi2000's Avatar
Default Re: power windows dont work but power locks work. need help. (solsi2000)
bump need help
Old Jul 7, 2008 | 06:09 PM
solsi2000's Avatar
ttt someone has to of had the same problem.
Old Jul 7, 2008 | 10:20 PM
solsi2000's Avatar
bump
Old Jul 7, 2008 | 11:07 PM
solsi2000's Avatar
nite bump
Old Jul 8, 2008 | 04:49 AM
solsi2000's Avatar
morning ttt
Old Jul 8, 2008 | 12:28 PM
solsi2000's Avatar
ttt
Old Jul 8, 2008 | 05:38 PM
SicBoY's Avatar
Both my windows stopped working, turned out to be a short. Try taking off the panels and messing with the wires, use a test light and hunt it down. I have to take my whole door off lol
Old Jul 8, 2008 | 06:42 PM
solsi2000's Avatar
Default Re: power windows dont work but power locks work. need help. (SicBoY)
so the fuse blew?
Old Jul 9, 2008 | 12:45 PM
SicBoY's Avatar
Na the fuse never blew one of the wires had a short and had to be replaced
Old Jul 9, 2008 | 07:41 PM
solsi2000's Avatar
damn what a pain in the *** that must have been. I checked all the fuses and they look fine. Also I tested the relay on a friends car and it works so now I am thinking it has to be the master switch.
Old Jul 13, 2008 | 11:30 AM
solsi2000's Avatar
ttt no ones windows stopped working all together??
Old Jul 13, 2008 | 12:46 PM
burnitdown's Avatar
in for possible answer. i had one window stop working all of a sudden, but has power
Old Jul 14, 2008 | 04:36 PM
solsi2000's Avatar
Default Re: (burnitdown)
hmm doesnt help. so what was it the switch?
Old Jul 14, 2008 | 04:54 PM
EquipedWithVtec's Avatar
Default Re: (solsi2000)
check to make sure the switch AND motor are getting power if both are then check your reg cuz i had the same problem with the one window not working and the other does and i found out my reg was bent badly and i cant even push it up or down so i no the motor wont be able to do it.. hope that helps
Old Jul 14, 2008 | 08:12 PM
solsi2000's Avatar
Default Re: (EquipedWithVtec)
from what i checked the wires to the switch are not getting any power. maybe im doing it wrong? any idea which specific wires to check?
Old Jul 15, 2008 | 08:42 PM
solsi2000's Avatar
bizump! i checked the plug that plugs into the master switch. only one wire going to it gets like .40 volts for some reason. at the fuse box under the dash all the window fuses are getting power. im stumped...
Old Jul 15, 2008 | 08:56 PM
phootbag's Avatar
I can't recall. Did the 94 get a multiplex? Could explain your voltage readings.
By the way, did you learn your lesson?
Old Jul 15, 2008 | 10:34 PM
solsi2000's Avatar
Default Re: (phootbag)
yeah i hate electrical stuff. but i dont see what harm splicing into 4 wires could have done. except that now none of my windows work.
Old Jul 16, 2008 | 06:00 PM
phootbag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote"> but i dont see what harm splicing into 4 wires could have done. except that now none of my windows work.</TD></TR></TABLE>
That sums it up. I recommend NOT probing for things without knowing what you are probing. You might end up spending a bunch of money that you shouldn't need to spend.
Looks like you need to take the car to a shop, preferably the dealer to have diagnosed.
Old Jul 16, 2008 | 08:20 PM
solsi2000's Avatar
fixed the problem. it was the backup light fuse. who would have thought to check that???
jermo
Sep 25, 2012 09:27 PM
russell707
Apr 26, 2010 04:33 AM
lilvietboy
Sep 12, 2008 10:29 PM
4playEkay
Mar 31, 2005 10:48 PM
