power windows and power locks dsnt work need help
ey guys im askin this question for my girl friend. her PW and PL doesn't work. we checked the fuse and there still good.. need help asap thanx
Re: power windows and power locks dsnt work need help (tarzjdm)
The harness/socket that's behind the door paneling might be disconnected. I had that happen once on a Civic for the power locks.
My apologies if you've already checked this, but better to go with the simple things first I guess.
Re: (tarzjdm)
To be honest, I'm not too sure about the power windows because I only had trouble with the locks. Basically, the socket wasn't plugged into its harness on the driver-side, which rendered the power lock switch useless.
I'm guessing that each door has it's own electrical connector for the power windows, so you could check those as well. If you have a shop manual handy, it might provide a diagram of the power window system for you to check before you start unscrewing the door panels.
Hope that helps.
Hope that helps.
Re: (msz-006)
do they not work all together or only when it is hot out. the reason is that honda are know for that and the fuel relays to go bad because the soder is broken down. i would resoder the boards. a buddie bought a car that the car would not start the power windows and locks did not work. this fixed it and had a nice car for only $1000 and a little soder.
jermo
09-25-2012 09:27 PM
