P28 on b18c1
Old Jul 6, 2008 | 12:12 PM
ChinoXdope's Avatar
Default P28 on b18c1
Hey I have a GSR b18c1 swap in my '92 Eg HB.Im using a chipped p28 and I don't think Im getting good gas milage.As a guess I'd say I'm getting 15mpg.My car also spits out light blackishgray smoke.Should I change the ECU to see if I can get better gas milage.
Thanks
Old Jul 6, 2008 | 12:23 PM
Syndacate's Avatar
Default Re: P28 on b18c1 (ChinoXdope)
Well black smoke indicates you're running rich - you could have the wrong fuel map burnt on.
Go get another chip from a company (plenty around here on H-T) - just a regular chip with a B18C1 basemap burnt onto it - pop it in, and see if there's a difference.
If there's no difference, then your problem is elsewhere, though I would just double check the contents of that chip - and a chip in and of itself isn't too much, I'd try that first.
EDIT:
Or if you can borrow a P72 to use, that's fine too, but I wouldn't bother buying one.
Also, if everything with the ECU is fine, change out ur primary O2 sensor.
Old Jul 6, 2008 | 01:41 PM
jax97hx's Avatar
i c ur in fl what part i might be able to help you ...i have all the nessisary equipment to put a tune on your ecu
Old Jul 6, 2008 | 02:36 PM
ChinoXdope's Avatar
Default Re: P28 on b18c1 (jax97hx)
I live in Broward in Pembroke pines and you?
Old Jul 6, 2008 | 02:38 PM
ChinoXdope's Avatar
Default Re: P28 on b18c1 (Syndacate)
Yea I've been wanting to use a p72 and see if it helped but none of my friends have any
Old Jul 6, 2008 | 03:18 PM
jax97hx's Avatar
jacksonville
Old Jul 6, 2008 | 03:23 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinoXdope &raquo;</TD></TR><TR><TD CLASS="quote">Hey I have a GSR b18c1 swap in my '92 Eg HB.Im using a chipped p28 and I don't think Im getting good gas milage.As a guess I'd say I'm getting 15mpg.My car also spits out light blackishgray smoke.Should I change the ECU to see if I can get better gas milage.
Thanks</TD></TR></TABLE>
A big question is, when do you start getting the smoke? at idle? 4k rpm? under heavy loads? WOT only? more info bro
Old Jul 6, 2008 | 03:39 PM
ChinoXdope's Avatar
Default Re: P28 on b18c1 (THC07)
when I gett off on 1st gear around 3,000 and ussualy ever gear I switch into it hits smoke
Old Jul 6, 2008 | 03:57 PM
longshot's Avatar
i had the same thing, in my b16 hatch, i swapped out the ecu for a jdm p30 (del sol dohc vtec ecu) and i get good gas mileage even with a CEL. go with a p 30.
Old Jul 9, 2008 | 10:31 PM
ChinoXdope's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">
A big question is, when do you start getting the smoke? at idle? 4k rpm? under heavy loads? WOT only? more info bro</TD></TR></TABLE>
I heard you do chipping?..Is there anyway you can be able to get me a chip with B18C1 basemap burnt onto it?
Old Jul 11, 2008 | 08:01 AM
THC07's Avatar
I heard you do chipping?..Is there anyway you can be able to get me a chip with B18C1 basemap burnt onto it?</TD></TR></TABLE>
Yea, Your still going to be using the P28 w/o IAB's?
PM'd
Old Jul 11, 2008 | 01:01 PM
ChinoXdope's Avatar
Well II have a P28 now thats chipped but my MPG is crappy,I was thinking of getting a P72 and chipping it,but Im still thinking on which one would help me better on gas.But as of now Im thinking about re-chipping my P28
Old Jul 11, 2008 | 04:44 PM
THC07's Avatar
sounds like you just need a stock p72 computer, which i have.
havent looked inside to see if i have chipped it yet, however its for sale.
if your concerns are gas MPG, you should get a p72 or have the IAB's installed onto your p28. stock maps w/ IAB's will get you good gas MPG again.
Old Jul 11, 2008 | 05:19 PM
ChinoXdope's Avatar
How much would you sell the P72 for? And if I wanted to keep the P28 how much would it cost to have the IAB's installed into my P28?..
Old Jul 11, 2008 | 05:26 PM
oneslowstd's Avatar
Dood just have someone on here, thats in your area of florida and get a good street tune spend the 200-250 bucks. That will help if not fix all of your problems. Not to mention you will make more power! That is unless you have another issue.
Old Jul 11, 2008 | 08:34 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinoXdope &raquo;</TD></TR><TR><TD CLASS="quote">How much would you sell the P72 for? And if I wanted to keep the P28 how much would it cost to have the IAB's installed into my P28?..</TD></TR></TABLE>
p72 for 130$ + ship.
Adding IABs for 25 to a p28 only!
Check around in your area for a p72 first to save yourself shipping. IMO a p72 is gonna be your best bet for the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd &raquo;</TD></TR><TR><TD CLASS="quote">Dood just have someone on here, thats in your area of florida and get a good street tune spend the 200-250 bucks. That will help if not fix all of your problems. Not to mention you will make more power! That is unless you have another issue.</TD></TR></TABLE>
yea at least 250 and remember its a stock gsr, so the HP or even TQ improvments are NOT worth the money.
Old Jul 11, 2008 | 11:28 PM
ChinoXdope's Avatar
For some odd reason I like using my P28,but yea your right,I think I'm just gunna go buy a P72 and see if that helps.But since my P28 is chipped and I pop V-Tec at almost 5,000 rpm wouldn't the stock P72 change that unless I chipp it.
Modified by ChinoXdope at 12:41 AM 7/12/2008
Old Jul 12, 2008 | 09:08 AM
THC07's Avatar
yea, lets just try a chip then, email me your mailing info and i mail you back paypal caddy. Jimjones07@sbcglobal.net
Old Jul 12, 2008 | 11:51 AM
ChinoXdope's Avatar
emailed!..
Old Jul 19, 2008 | 02:33 PM
Mugenkid's Avatar
I have a P73 ecu if you want that 100$
540dude
Engine Management and Tuning
23
Dec 29, 2011 06:22 AM
JDMb18c1HATCH
Aug 20, 2010 07:06 AM
wrxya33
Jun 26, 2007 02:13 PM
Azn Kenny
Aug 13, 2006 12:05 PM
Vic Nyce
Apr 3, 2003 03:42 PM
