chrome tuned issue leans out at 5psi regardless of rpm
I'm in the process of tuning my turboed zc with chrome and for some reason at 5psi it whants to go instantly lean. I can partial throttle it to red line and have plenty of fuel as long as I keep it lower that 5 lbs.
Info:cut is set at 7800 rpm (built head) and launch control at 4200. I'm running rc 750s and a walbo 255. Gm 3 bar that worked in last setup.
I'm gonna try a different map sensor but if that doesn't work, other ideas would be appreciated.
https://honda-tech.com/zeroforum/124
u should prolly post that kind of question in there im sure u can get a lot more help from those guys than most guys in here. only thing i can think of is maybe the wideband u are using may not be hooked up correctly or may be broken already. i do know that some of the widebands will work like a light show if not hooked up correctly
Do you have the GM 3bar promagrammed into your current ROM?
*edit* it sounds like its doing a cut a 5psi obviously, go to setting and option and see what the boost limit is.
j0keefe21
12
Jun 13, 2010 12:30 AM
27psi
Engine Management and Tuning
18
Jul 27, 2008 01:00 PM
