U guys ever tried this ?????????????????
Old Jul 5, 2008 | 08:23 PM
si_motor_spt's Avatar
Default U guys ever tried this ?????????????????
Hey guys and gals, have u guys ever tried installing an adjustable fuel pressure regulator and turning the fuel pressure to 22-24psi? is that safe enough for a DD? after i adjusted it to that psi, i drove the car with my brother and it idled fine, accelarated fine also and when i opened it up, it sounded great, my MPG's were way better also,(i had a lot of intown driving) and that killed my MPG's. But its ok to run it like that right??????
Old Jul 5, 2008 | 08:43 PM
Nbboy7's Avatar
your gona lean out
Old Jul 5, 2008 | 08:57 PM
team_exceed's Avatar
Default Re: (Nbboy7)
x2. think about what your doing... messing with the stock settings on a stock motor... probably not a good idea. granted, it works for a while, but that doesnt mean its a good idea. its like turning the boost up too high, ya its fun and it runs fast, but the fun will come to an end faster than the car was running. honda sets things the "best" stock and legal, way.
Old Jul 5, 2008 | 09:02 PM
Relic1's Avatar
22-24psi is around half the stock pressure, you're running the engine dangerously lean. If not impossibly lean. (engine death is not far off)
If you want slightly better mpg, drop it a few psi, not 20-25.
Old Jul 5, 2008 | 09:16 PM
RedneckRicer's Avatar
most honda's are between 38-42 PSI stock so go ahead and run that fuel pressure
Old Jul 5, 2008 | 09:41 PM
ke98248's Avatar
Default Re: (RedneckRicer)
Old Jul 5, 2008 | 11:59 PM
Default Re: U guys ever tried this ????????????????? (si_motor_spt)
Thanks for the info guys, that really helped.....
Old Jul 6, 2008 | 12:41 AM
nasteawhun's Avatar
Well do this, check the color of your spark plug. pull them out and see. if they are gray or white it NO good. if there like tarnish or brown color. your ok. if they are melted i know a guy that sells motors cheap.
poodlemuffer
Engine Management and Tuning
Feb 1, 2014 09:24 AM
camden
May 29, 2009 04:13 PM
blue_hatch
Mar 6, 2005 11:39 PM
vtecteg00
Jun 12, 2004 08:09 AM
RTE117
Apr 22, 2004 02:02 PM
