car won't idle right..
like the title says...
after driving for a while...my car have trouble idling..it bounces between 300 to 1200rpm up and down when it's on nuetral...what could be the reason?
Jeff-
Jeff-
in my case the idle position was too high.... i still have slight issue but thats another story all together. just play with your idle screw when the car is warmed up or when it starts the funny idle. i drove mine around for about 15 minutes (errands) then came home, revved it up until the idle started bouncing, then play with the idle screw until it was smooth again. Hope this helps.
[Modified by turtleb16a, 9:51 AM 7/19/2002]
There's a sensor on the back of the intake manifold (iavc?)... disconnect it and see if it idles normally, if it does, that's your problem.
are you throwing any codes?
another fix is to clean out your throttle body with carb cleaner. remove it from the car, and clean it out.
dirtyharryhatch
Dec 14, 2011 05:45 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
