leaking oil after turbo installation
Old Jul 1, 2008 | 10:49 AM
agu681's Avatar
Default leaking oil after turbo installation
ok i just installed a turbo on my 93 eg but i have a problem, i got oil coming from a box right next to the oil filter it seems like when the car is on, theres air blowing out of there along with oil. the engine is a d16a. sohc. is there a seal around that area? what should i do?
Old Jul 1, 2008 | 10:59 AM
lv6l's Avatar
That box you describe sounds like your "oil breather chamber" This could be where your oil is leaking. There is a hose connect to it from the driver side. There is also an o-ring that goes between the oil breather chamber unit itself and the motor block.
Modified by lv6l at 12:07 PM 7/1/2008
Old Jul 1, 2008 | 12:00 PM
marcs1337's Avatar
sounds like you messed up LOL
Old Jul 1, 2008 | 12:20 PM
hotrod99's Avatar
Default Re: (marcs1337)
That box is a baffle for the PCV system. Make sure the PCV hose is inserted into it all of the way. It also slips into the block and has an o-ring seal. Remove the 2 10mm bolts that hold it in and replace the o-ring if that is the source of the leak.
Old Jul 1, 2008 | 01:18 PM
blk92_d16's Avatar
I foresee a post soon to come saying "I've got a hole in my block...what can I do?"
raverx3m
Mar 14, 2015 10:12 PM
HomeDepotMade
Sep 26, 2008 09:13 AM
avotegra
Sep 4, 2008 09:43 AM
EngineNoO9
Honda Motorcycles
Sep 10, 2006 07:47 PM
weak_sauce
Sep 24, 2005 07:40 AM
