Having Engine Problem with my delsol
Old Jun 30, 2008 | 07:12 PM
twr176's Avatar
Default Having Engine Problem with my delsol
ok i have a 94 sol with a d16z6 & every time i started for the first time in the day it fires right up but after i drive to where ever im going to, when i shut it off and dont let it cool off it struggles to start right up unless i give it a lil gas it will start up. what could be the problem the CEL isnt on so i cant troubleshoot it. Has anyone experienced this issue????
Old Jun 30, 2008 | 08:24 PM
JdelMsolG's Avatar
Default Re: Having Engine Problem with my delsol (twr176)
whens the last time you had an ol' tune up? i.e. plugs wires cap fuel filter air filter oil filter blah blah
Old Jun 30, 2008 | 08:30 PM
sorullo's Avatar
two things... could be the master relay, or the fuel pump relay....i used to have the similar problem and i change both at the same time.. and guess what.. it works.!!
Old Jun 30, 2008 | 09:37 PM
twr176's Avatar
Default Re: Having Engine Problem with my delsol (JdelMsolG)
1month ago replaced distributer,plugs,timing belt,water pump,oil,flushed rad. can da problem be da fuel filter?
Old Jun 30, 2008 | 09:40 PM
twr176's Avatar
Default Re: Having Engine Problem with my delsol (sorullo)
lets say both of those relays are bad will da car turn on?
Old Jun 30, 2008 | 09:44 PM
Hanmin's Avatar
check your compression when the motors cold and when the motors hot.
Old Jun 30, 2008 | 11:52 PM
4drkidd's Avatar
Wow, story of my life..
I'm having the same issue, it cant be the fuel filter because I changed mines out and I'm still having that problem.
Trying changing your fuel pump and check your compression like what Hanmin said.
And also check your Main Relay, I changed mines out and it's giving me a little better response.
Old Jul 1, 2008 | 12:02 AM
rSol93's Avatar
Main Relay, I had the same problem in my del sol.
Old Jul 3, 2008 | 06:36 PM
twr176's Avatar
Default Re: (rSol93)
where is da main relay located?
Old Jul 4, 2008 | 03:35 PM
twr176's Avatar
anyone?????
Old Jul 4, 2008 | 05:30 PM
carboncivic94's Avatar
I had this issue. I change the head gasket and she ran great after that.
Old Jul 6, 2008 | 07:22 PM
twr176's Avatar
Default Re: Having Engine Problem with my delsol (carboncivic94)
damm head gasket huh .
i'll do a compression test and from there but i was hoping it would be something smaller.
Old Jul 6, 2008 | 08:18 PM
rSol93's Avatar
Main relay is behind the fuses under the dash
Im pretty sure, mine was dangling down, but im pretty sure thats where it goes.
89canefighter
Mar 15, 2009 02:51 PM
bignosewhipper
16
Jul 3, 2008 05:38 PM
00BoostedGSR
Sep 25, 2007 07:15 AM
lude1888
Jul 22, 2006 03:08 PM
LSegHatchy
Jul 25, 2004 06:03 PM
