P0133 code on 2000 civic ex???
i have IHE and test pipe only 76000k on it,check the code gimme p0133 bank 1 slow response,i tried changin the o2 sensor twice still giving me same code if i drive it for a day,any help!!!?????
Re: P0133 code on 2000 civic ex??? (jdmek9spoon2008)
* The oxygen sensor is faulty
* The wiring to the sensor is broken / frayed
* There is an exhaust leak
* Check and fix any exhaust leaks
* Check for wiring problems (shorted, frayed wires)
* Check the frequency and amplitude of the oxygen sensor (advanced)
* Check for a deteriorating / contaminated oxygen sensor, replace if necessary
* Check for inlet air leaks
* Check the MAF sensor for proper operation
reset the code and see if it comes back.
how do i check the map sensor by using a tester anyone know how???or map sensor diagram?which is ground,signal,positive?thanks for the replies guys!!!
