d15b block d16y8 head mini-me into odb2 d16y8 civic
so im getting a minime swap for really cheap to replace my old worn y8. im concerned getting the obd1 block installed (mounts) and running (ecu/sensors). from what i remember a z6 or y8 ecu can run either motor including mini-me's (harness compatability aside). being an obd2 head the alt/dist plugs will all work so will i be able to get the mini me to plug and play into my harness/ecu? I think the only problem ill have is a check engine for the crank sensor, will that cause it not to run? is there any cheap fix for that?
and about mounts, are obd1/2 d series the same?
No it will run fine..i have the same swap in my del. Yes ur right about the engine light,...the code flashes for the crank sensor,..but the car runs great.
so no wiring/mount issues with the b7 block?
im going to search if there's a way to wire a crank sensor in the obd1 block.
if i hook up all obd2 parts, and buy adapter harness to use obd1 ecu, will that work?
Modified by dafuzzbudd at 6:13 PM 7/2/2008
you should look for a y7 block, they are very cheap, usually like 100$ for a motor, its already obd2(crank sensor)
, and when mated with a y8 head it will bump up compression.
i think im going to.
the seller of the mini-me i was going to buy flaked
my goal is to learn how to rebuild a d-series.
i need to get my crap outta my car,
it has a hesitant low-range and slipping clutch but doesnt burn oil though
so i need to buy a temp mini-me/y8/z6 while i spend the cold winter rebuilding
Lyle_57IAL
Jul 20, 2011 11:37 PM
Dasfinc
16
Feb 11, 2008 09:37 AM
Offer
Oct 7, 2007 09:05 PM
