test pipe
i just put a comptech header in my 03 dc5 but now i want a hi flow cat and i was reading the description on the megan hi flow test pipe and it had a note 'although the o2 plugs are there an o2 simulator maybe needed to stop from any check engine lights on' what does that mean exactly?
thanks for your help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03dc5Ray »</TD></TR><TR><TD CLASS="quote">i just put a comptech header in my 03 dc5 but now i want a hi flow cat and i was reading the description on the megan hi flow test pipe and it had a note 'although the o2 plugs are there an o2 simulator maybe needed to stop from any check engine lights on' what does that mean exactly?
thanks for your help</TD></TR></TABLE>
The Test Pipe has no catalytic converter. What happens is that the second 02 sensor won't read a correct temperature change and think that you've got a malfunctioning cat, it'll throw a check engine light, and you'll be up a creek. Test pipes are also going to fail any emissions test, so don't even try it if you have to get emissions....
Anyway, here's a thread regarding 02 simulators, or "defouler" as they call it.
http://www.8thcivic.com/forums....html
Anyway, if you don't have KPRO or a simulator, you'll have a CEL code.
So if i have KPRO or that simulator the test pipe should work fine?? how do i go about getting one of those simulators??
By the way I love that anime!!! lol
