Test pipe question
Old Dec 1, 2004 | 06:18 AM
brkdwn5's Avatar
Default Test pipe question
Hey all,
I am planning on putting a test pipe, or high flow cat. But, I have heared that this causes a loss in power. Is this true, and should I do this mod to my '99 LS?
Old Dec 1, 2004 | 10:12 AM
gsrious's Avatar
Default Re: Test pipe question (brkdwn5)
i advise you to convert to obd1 before doing a test pipe.
Old Dec 1, 2004 | 10:14 AM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: Test pipe question (red dc2)
dont listen to him i gutted my cat and i am obdII no problems no CEL's
Old Dec 1, 2004 | 10:16 AM
Sack Master's Avatar
IMO a test pipe sounds like crap. Just get a high flow cat and an o2 simulator. But make sure the rest of your exhaust is up to par.
Old Dec 1, 2004 | 10:46 AM
dFreezy's Avatar
Default Re: Test pipe question (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">IMO a test pipe sounds like crap. Just get a high flow cat and an o2 simulator. But make sure the rest of your exhaust is up to par.</TD></TR></TABLE>if he's going to get a cat, he should get one that has an o2 bung so he wouldnt need the o2 simulator. i definitely agree though, test pipes add a degree of 'raspiness' sound to an exhaust. a good high flow cat (like carsound) will only rob the car of a few hp if any, the amount is neglible.
Old Dec 1, 2004 | 11:28 AM
RoadconeTuning's Avatar
Default Re: Test pipe question (dFreezy)
you will loose a little low end tq but i doubt youll notice loosing any tq and youll gain some top end. if you use a peice of thin pipe then it will be raspy but a slightly thicker pipe will sound better.
Old Dec 1, 2004 | 11:33 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Test pipe question (Dude29662)
If everything else about your exhaust system is stock, don't get a test pipe. In honesty, it will sound like ****. You probably wont benefit from any power gains since (if) you have the stock straw piping.
Think about it this way... if you're planning to stay all motor, then the highest I would go is 2.75" piping (custom mandrel bends) exhaust system from the header back including a high flow cat or test pipe. Else, if you are going the FI route and plan to make more than 300whp, then a 3" will suffice.
What are your plans anyhow?
Old Dec 1, 2004 | 04:40 PM
brkdwn5's Avatar
Thanks for opinions. As of right now I plan to go all motor.
jdmhondaboi626
Jan 22, 2008 03:17 PM
401tuner
Jun 3, 2007 04:03 PM
yeegsr
Sep 4, 2004 09:35 PM
Inextricabledrvr
Mar 19, 2004 05:27 AM
H23A1LUDE
Jun 5, 2003 08:17 AM
