car hiccups and stutters at low rpm's when throttle is pressed generously?
Old Jun 27, 2008 | 01:57 PM
sean2000gt's Avatar
Default car hiccups and stutters at low rpm's when throttle is pressed generously?
it's a 2000 gsr. it's been like this since i bought it but took a friend for a ride the other day and he said it just wasn't right. when im below 2-2.5k rpm's, if i give any significant amount of throttle the car wont accelerate, it just hiccups and bucks and everything. i thought it mighta just been normal, just a rev happy car, but i want to check because it's very annoying. i mean if im pulling away from a stop light in first gear at 5mph and step on it, the car just bucks and goes crazy, i have to have it above 2500rpm's til i can stomp on it. please help. thanks in advance.
Old Jun 27, 2008 | 07:48 PM
sean2000gt's Avatar
anyone?
Old Jun 27, 2008 | 07:51 PM
lmike6453's Avatar
Well it is definitely not normal. Things I would check in order:
Throttle Cable
Air Filter
Grounds
Mounts
Fuel
Spark
Compression
Old Jun 27, 2008 | 08:39 PM
LordAphotic's Avatar
have you messed with the ECU?
it sounds like your fuel maps are messed up...
Did u put the ECU from another car thinking it was gona somehow make ur car better?
Old Jun 28, 2008 | 12:17 PM
HGZ's Avatar
HGZ
Default Re: car hiccups and stutters at low rpm's when throttle is pressed generously? (sean2000gt)
when i had stuttering/hiccuping problems in lower rpms it was a combination of a dirty fuel filter, bad spark plugs and mangled up distributor rotor. i also replaced my o2 sensor but found out i didn't really need to, but good to replace if its been awhile.
good luck!
Old Jun 28, 2008 | 01:32 PM
tasty's Avatar
Default Re: car hiccups and stutters at low rpm's when throttle is pressed generously? (HGZ)
i have the same problem, i have tried everything except retuning the car because im finishing the port polishing on the head, when i retune again and it stops i will let you know
Old May 20, 2014 | 08:53 AM
gabrielsousa's Avatar
@tasty i have same problem, what was your problem ?
Old May 21, 2014 | 10:11 AM
tamboo's Avatar
10 Year Member
check your cams for proper alignment.
could be tps too.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
Old May 21, 2014 | 08:03 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Check the timing, fuel, and ignition components.
Old May 22, 2014 | 05:50 AM
could be tps too.
https://honda-tech.com/forums/showthread.php?t=2830131
tried 3 TPS, 2 used and 1 new, so TPS isnt.
0.46v closed
4.56v open
Old May 22, 2014 | 05:53 AM
tomorrow i will test new spark plugs (Denso 5304 IK20 Iridium) ?
and new spark cables,
i will report
at high RPM and higer speed i dont have problems....
my dizzy is in 16º
Old May 22, 2014 | 06:35 AM
i did a test...
with a strange result
with engine running and idle fluctuating i unplug ONE spark cable, plug again and the idle stop fluctuating
B serious's Avatar
The stock plugs are NGK/Denso platinum. Stick with those or buy the NGK copper ones (V power).
Kid-jdm-teggy
Nov 24, 2013 07:38 AM
NemesisCBR
May 9, 2012 06:21 AM
VTECth1s
Feb 15, 2008 09:09 PM
MeanGreenEG9
Mar 14, 2003 02:20 PM
kefka
Feb 13, 2002 11:36 PM
