problems help please...
i have a b18c,i am having bad throttle response,i am going ahead and changing out the plugs,wires and i am gong to check my timing. is there anything else i should check?
Re: problems help please... (madeinjapan)
could be running a bit lean..if so, it ll feel like ur not getting enough fuel..or maybe just a dirty fuel delivery sys. easy enough to solve with some sea foam and injector cleaner..then there s trying a higher octane gas if ur using regular
SOUND TO ME IT HAS TO MUCH FUEL WHEN YOU GET ON IT IT STARTS TO BOG RIGHT THEN WHEN IT GET HIGHER RPM ITS OK RIGHT.CHECK TO SEE IF ALL YOUR SPARK PLUGS ARE GETING SPARK.AND CHECK FUEL PRESSURE AND DO A COMPRESSION TEST TO AND SET THE VALVE WHILE YOUR AT IT
sean2000gt
05-22-2014 06:35 AM
si del sol 94
18
09-16-2009 07:39 PM
