HELP, MY EX TACH isn't working!!
Old Jun 26, 2008 | 11:39 PM
RCurioso88's Avatar
Default HELP, MY EX TACH isn't working!!
How's it goin guys, got a bit of a problem. I recently removed the white facing of my '98 EX tach that my brother put on there and when I did, the back light wasn't lighting up at first. So i replaced the bulbs and it still didn't work. Then as if that wasn't bad enough, now the whole tach doesn't function. The RPM isn't working anymore, the speedo isn't moving, the gas and temp gauges are far off. I'm really hoping that it's repairable cuz i'm new to modifying things but i'm willing to learn how to fix it. Anyoen got any tips/tricks/help?
Old Jun 27, 2008 | 12:35 AM
koolkevin1107's Avatar
Default Re: HELP, MY EX TACH isn't working!! (RCurioso88)
id u remember to plug the harnesses back in? that might b the problem, u forgot a harness. Also, u might wanna check ur fuses under the dashboard. Maybe you blew something.
Old Jun 27, 2008 | 05:48 AM
davefromPA's Avatar
Default Re: HELP, MY EX TACH isn't working!! (koolkevin1107)
fuses would be my first place to start. after that, make sure its connected and the screws in the back of the cluster are tight. definatly check fuses. there is one that controls all this stuff and it might be blown. i just saw someone post it up in another thread cause the guy doesnt have turn signals but has parking lights. search for that and you might get your answer
Old Jun 27, 2008 | 08:16 PM
RCurioso88's Avatar
thanks guys, i'm going to try that tomorrow. I hope that's it, if not i'll post another one. THX
Old Jun 28, 2008 | 10:03 PM
RCurioso88's Avatar
90si-rex
Apr 8, 2015 10:48 PM
b20acura
Jan 14, 2012 01:02 AM
99CivicSiBrian
Feb 24, 2006 03:32 PM
